WB3FFV
- Dec 22, 2020
I know this is still a work in progress, and at the moment I am running the latest Master release from Dec 25th. I am trying to setup a test Scale system to handle all the functions of my current TrueNAS Core box, so I can test and get ready to use Scale when it releases.
Trying to configure a couple shares, I can see they have for sure made some changes to the configuration screens for SMB shares. When I create a share, it shows with permissions for a "User Obj" and a "Group Obj" which to me would indicate I could define and object to cover multiple things and call it, but I see no place to do this. If I just try and mount an SMB share to a Windows 10 machine with the default settings, then it fails, so I had to go change them to my user and group id to make it work.
Is there any information or document anyplace that will explain the correct way to configure up shares in Scale, as at the moment I am left scratching my head..
