SMB Performance with Truenas 12
Morpheus187
Hello
I upgraded to Truenas 12.0-u7 and noticed that the playback of certain movies on my Nvidia Shield got very laggy. ( 4K hdr files, very large )
I then reverted back to FreeNas 11.2-U8 and the problem went away, playback is absolutely smooth without any stuttering or lagging.
Truenas/Freenas is connected via a 10 GB link ( File Transfer from windows machine yielded about 300-400 MB/s, FreeNas around 400-600 MB/s. Shield is connected with gigabit ethernet. Playback of the same file works on my windows machine without stuttering.
Nvidia Shield pulls the files from Freenas/Truenas via SMB protocol ( Kodi 19 is installed )
Is there anything new or changed with SMB in Truenas that could explain this performance problems?
Specs:
Xeon E3-1245-v5 ( 8 core )
64GB ECC ram
8x6 TB WD-RED
10Gbit Ethernet
Thank you very much
Morpheus
Morpheus187
Sorry for the late response
Here is the output of testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
# Global parameters
[global]
        aio max threads = 2
        bind interfaces only = Yes
        disable spoolss = Yes
        dns proxy = No
        enable web service discovery = Yes
        kernel change notify = No
        load printers = No
        logging = file
        max log size = 5120
        ntlm auth = ntlmv1-permitted
        registry shares = Yes
        restrict anonymous = 2
        server min protocol = NT1
        server role = standalone server
        idmap config * : backend = tdb
        directory name cache size = 0
        dos filemode = Yes
[Storage]
        ea support = No
        path = /mnt/VOL1/Storage
        read only = No
        vfs objects = zfs_space zfsacl streams_xattr
        nfs4:chown = true
[Backup]
        ea support = No
        path = /mnt/VOL1/backup
        read only = No
        nfs4:chown = true
I did further testing and I discovered that smb probably isn't the problem as I noticed "Rx FCS Errors" and "Received with MAC Errors" on my switch.
When I changed back to Freenas, the problem went away. Now I wanted to collect troublshooting information and the problem seems to also have vanished for Truenas, the system is now up for 2 days and hasn't had any network related errors anymore, video playback is also smooth. I cannot rule out a strange "cabling" issue that led to intermittend failures that just happened with truenas and not with freenas.
It may also be a netzwork driver settings issue, but as the problem isn't appearing anymore, I can't collect any network related troubleshooting information. I will start a new thread in case the problem comes back and I can reliable trace it down to a Truenas issue.
Thank you very much.
