SMB Mount Issue
dr_sherman
I have been running a FreeNAS box with several SMB shares for years. I upgraded TrueNAS 12.0-U3 and I am experiencing issues accessing my mapped drives on my Windows 10 box. Nothing has changed in terms of configuration but when I have attempted to remove and re-mount the drives I am promoted to enter my credentials twice and then the following error is returned
The network path \\server\share could not be found
I logged in the 'log.smbd' log and the following error is returned at the time I am attempting the mount:
Connection reset by peer
[2021/04/29 19:22:05.510579,  0] ../../lib/util/tevent_debug.c:66(samba_tevent_debug)
The shares are still present within the UI and marked to enabled. If I browse to \\server the window is returned blank.
I am searched around although it appears that some people have had similar issues in the past I am a little stuck.
Thanks for your help in advance!
How do you view the log.smdb log?
Either at the cli:
ee /var/log/samba4/log.smbd
Or with something like FileZilla and browse to that path.
