SMB language windows problem
virusbcn
I have a Windows DC domain, Freenas integrated in domain and give users from ldap, the users have a profile mobile they copy all your users directory on close and start session and synchronize with share \\server\profile\%username% , ok ??? , well i move the share \\server\profiles to a \\freenas\profiles and .... freenas don't copy the shares typical of Windows 7 like "desktop" ("escritorio" in Spanish) etc... etc..
The image attached show in left the mobile profile of one user on my domain in one windows server and it's ok and in the right you can show the share profile of Freenas, you can view how missing directories, in the event viewer of machines can read who can not create shares like, desktop, etc....
Any ideas ???
D
dlavigne
Guest
Were you able to resolve this? If not, what is the build version of FreeNAS (from System -> Information)?
virusbcn
No, i'm not able to working, i have the last version ->
FreeNAS-9.10.1-U4 (ec9a7d3)
virusbcn
Thank you dlavigne, here you are...
[global]
	server max protocol = SMB3
	interfaces = 127.0.0.1 192.168.19.250
	bind interfaces only = yes
	encrypt passwords = yes
	dns proxy = no
	strict locking = no
	oplocks = yes
	deadtime = 15
	max log size = 51200
	max open files = 234065
	logging = file
	load printers = no
	printing = bsd
	printcap name = /dev/null
	disable spoolss = yes
	getwd cache = yes
	guest account = nobody
	map to guest = Bad User
	obey pam restrictions = yes
	directory name cache size = 0
	kernel change notify = no
	ea support = yes
	store dos attributes = yes
	lm announce = yes
	unix extensions = no
	acl allow execute always = true
	dos filemode = yes
	multicast dns register = no
	domain logons = no
	idmap config *: backend = tdb
	server role = member server
	workgroup = ESPINOS
	realm = ESPINOS.LOCAL
	security = ADS
	client use spnego = yes
	cache directory = /var/tmp/.cache/.samba
	local master = no
	domain master = no
	preferred master = no
	ads dns update = yes
	winbind cache time = 7200
	winbind offline logon = yes
	winbind enum users = yes
	winbind enum groups = yes
winbind nested groups = yes
	winbind use default domain = no
	winbind refresh tickets = yes
	idmap config ESPINOS: backend = rid
	idmap config ESPINOS: range = 20000-90000000
	allow trusted domains = no
	client ldap sasl wrapping = plain
	template shell = /bin/sh
	template homedir = /home/%D/%U
	netbios name = FREENAS
	pid directory = /var/run/samba
	create mask = 0666
	directory mask = 0777
	client ntlmv2 auth = yes
	dos charset = ASCII
	unix charset = UTF-8
	log level = 1
	socket options = TCP_NODELAY IPTOS_LOWDELAY
	min receivefile size = 16384
	aio read size = 16384
	aio write size = 16384
	ea support = no
	store dos attributes = no
	map archive = no
	map hidden = no
	map readonly = no
	map system = no
	case sensitive = yes
[Copias]
	path = /mnt/RaidZ/Copias
	printable = no
	veto files = /.snapshot/.windows/.mac/.zfs/
	writeable = yes
	browseable = yes
	vfs objects = zfs_space zfsacl streams_xattr aio_pthread
	hide dot files = yes
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
	zfsacl:acesort = dontcare
	veto files = /Thumbs.db/Temporary Items/.DS_Store/.AppleDB/.TemporaryItems/.AppleDouble/.bin/.AppleDesktop/Network Trash Folder/
.Spotlight/.Trashes/.fseventd/
	delete veto files = yes
[Fotos]
	path = /mnt/RaidZ/Fotos
	printable = no
	writeable = yes
	browseable = yes
	shadow:snapdir = .zfs/snapshot
	shadow:sort = desc
	shadow:localtime = yes
	shadow:format = auto-%Y%m%d.%H%M-1w
	shadow:snapdirseverywhere = yes
	vfs objects = shadow_copy2 zfs_space zfsacl streams_xattr aio_pthread
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
[Perfiles]
	path = /mnt/RaidZ/Perfiles
	printable = no
	writeable = yes
	browseable = yes
	shadow:sort = desc
	hide dot files = no
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
virusbcn
Maybe this is a first post here that anyone can help me ???
Enviado desde mi SM-G930F mediante Tapatalk
bigphil
How are you controlling the behavior of the roaming profiles? via group policy or individual settings on each AD user account? If using group policy, be sure to check for any "folder redirection" settings (i.e. user configuration>Policies>Windows Settings>Folder Redirection) you may have applied that are still pointing to the old path. Another thing to check if using group policy is run an RSOP report on a machine and user that are experiencing the problem to verify the setting is getting set from another policy in may be inheriting from somewhere else.
