Grinas
- May 4, 2017
Is there an alternative to smartctl.
Literally every drive failure i have had smartctl shows as pass but i am still bombarded with alerts in the console/commadline which makes using the host via CLI a night mare.
I am currently getting alerts for a spare drive in CLI but smartctl says it passed the test.
This drive is only a few weeks old and dont want to have to pay shipping costs for RMA unless i have to.
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.63-production+truenas] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST10000VE001-3BX101
Serial Number: WP00PJ2F
LU WWN Device Id: 5 000c50 0edac4c7b
Firmware Version: EV01
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5319
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Feb 14 12:28:53 2024 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 559) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 862) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 081 064 044 Pre-fail Always - 126570497
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 14
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 085 060 045 Pre-fail Always - 309835356
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 4194
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 13
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 066 066 000 Old_age Always - 34
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 8590131203
190 Airflow_Temperature_Cel 0x0022 070 040 000 Old_age Always - 30 (Min/Max 24/33)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1916
194 Temperature_Celsius 0x0022 030 060 000 Old_age Always - 30 (0 24 0 0 0)
197 Current_Pending_Sector 0x0012 100 085 000 Old_age Always - 6
198 Offline_Uncorrectable 0x0010 100 085 000 Old_age Offline - 6
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 4044 (219 103 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 105942459784
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 200985233951
SMART Error Log Version: 1
ATA Error Count: 46 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 46 occurred at disk power-on lifetime: 884 hours (36 days + 20 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 00 00 ff ff ff 4f 00 31d+02:23:11.265 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 31d+02:23:10.264 WRITE FPDMA QUEUED
61 00 10 30 01 00 40 00 31d+02:23:09.825 WRITE FPDMA QUEUED
61 00 08 00 43 03 40 00 31d+02:23:09.752 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 31d+02:23:09.680 WRITE FPDMA QUEUED
Error 45 occurred at disk power-on lifetime: 884 hours (36 days + 20 hours)
61 00 00 ff ff ff 4f 00 31d+02:23:08.553 WRITE FPDMA QUEUED
61 00 08 00 43 03 40 00 31d+02:23:08.553 WRITE FPDMA QUEUED
61 00 10 ff ff ff 4f 00 31d+02:23:08.553 WRITE FPDMA QUEUED
60 00 80 ff ff ff 4f 00 31d+02:23:08.553 READ FPDMA QUEUED
Error 44 occurred at disk power-on lifetime: 879 hours (36 days + 15 hours)
61 00 80 ff ff ff 4f 00 30d+21:03:16.383 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+21:03:15.862 WRITE FPDMA QUEUED
61 00 80 ff ff ff 4f 00 30d+21:03:15.857 WRITE FPDMA QUEUED
61 00 80 ff ff ff 4f 00 30d+21:03:15.856 WRITE FPDMA QUEUED
61 00 80 ff ff ff 4f 00 30d+21:03:15.855 WRITE FPDMA QUEUED
Error 43 occurred at disk power-on lifetime: 877 hours (36 days + 13 hours)
61 00 00 ff ff ff 4f 00 30d+19:21:04.056 WRITE FPDMA QUEUED
61 00 08 00 43 03 40 00 30d+19:21:03.525 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+19:21:03.055 WRITE FPDMA QUEUED
61 00 10 ff ff ff 4f 00 30d+19:21:03.034 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+19:21:02.678 WRITE FPDMA QUEUED
Error 42 occurred at disk power-on lifetime: 877 hours (36 days + 13 hours)
61 00 08 00 43 03 40 00 30d+19:15:20.901 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+19:15:20.551 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+19:15:19.910 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 30d+19:15:19.731 WRITE FPDMA QUEUED
60 00 80 ff ff ff 4f 00 30d+19:15:19.461 READ FPDMA QUEUED
# 1 Conveyance offline Completed without error 00% 68 -
# 2 Extended offline Completed without error 00% 13 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
