SMART error?
George51
Got this email (twice at exactly the same time) last night:
This message was generated by the smartd daemon running on:
host name: freenas
DNS domain: local
The following warning/error was logged by the smartd daemon:
Device: /dev/ada1, Self-Test Log error count increased from 0 to 1
Device info:
WDC WD10EFRX-68PJCN0, S/N:WD-WCC4J3542112, WWN:5-0014ee-25f5645f2, FW:01.01A01, 1.00 TB
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
No additional messages about this problem will be sent.
Since then, I've run a short test, and a long test is currently running on ada1. Here is the bottom bit of the output of smartctl -a /dev/ada1 ( I don't know how to scroll up within the shell window...)
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       24
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       2
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       75
194 Temperature_Celsius     0x0022   113   102   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       1
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      7251         -
# 2  Extended offline    Completed: read failure       40%      7249         1219691232
# 3  Short offline       Completed without error       00%      7228         -
# 4  Short offline       Completed without error       00%      7204         -
# 5  Short offline       Completed without error       00%      7180         -
# 6  Short offline       Completed without error       00%      7156         -
# 7  Short offline       Completed without error       00%      7132         -
# 8  Extended offline    Completed without error       00%      7082         -
# 9  Short offline       Completed without error       00%      7061         -
#10  Short offline       Completed without error       00%      7037         -
#11  Short offline       Completed without error       00%      7013         -
#12  Short offline       Completed without error       00%      6989         -
#13  Short offline       Completed without error       00%      6965         -
#14  Extended offline    Completed without error       00%      6914         -
#15  Short offline       Completed without error       00%      6893         -
#16  Short offline       Completed without error       00%      6869         -
#17  Short offline       Completed without error       00%      6845         -
#18  Short offline       Completed without error       00%      6821         -
#19  Short offline       Completed without error       00%      6797         -
#20  Extended offline    Completed without error       00%      6747         -
#21  Short offline       Completed without error       00%      6725         -
Where do I go from here?
Cheers
If you ssh to the machine rather than using the Shell button from the web GUI, you'll usually be able to scroll back and capture everything. Or you could "page" the output, so you could read it all, by doing "smartctl -a /dev/ada1 | more". Or you could send the output to a file on your pool by doing "smartctl -a /dev/ada1 > smartinfo.txt".
But all of those aside, your drive appears to be failing. If the long SMART test you're currently running also shows an error, I'd RMA the drive if under warranty, or buy a new one if not, and replace it.
George51
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p10 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD10EFRX-68PJCN0
Serial Number:    WD-WCC4J3542112
LU WWN Device Id: 5 0014ee 25f5645f2
Firmware Version: 01.01A01
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Mar  7 16:19:52 2015 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (13800) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 157) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   133   131   021    Pre-fail  Always       -       4325
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       24
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -       7259
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   114   102   000    Old_age   Always       -       29
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Extended offline    Completed without error       00%      7254         -
# 2  Short offline       Completed without error       00%      7251         -
# 3  Extended offline    Completed: read failure       40%      7249         1219691232
# 4  Short offline       Completed without error       00%      7228         -
# 5  Short offline       Completed without error       00%      7204         -
# 6  Short offline       Completed without error       00%      7180         -
# 7  Short offline       Completed without error       00%      7156         -
# 8  Short offline       Completed without error       00%      7132         -
# 9  Extended offline    Completed without error       00%      7082         -
#10  Short offline       Completed without error       00%      7061         -
#11  Short offline       Completed without error       00%      7037         -
#12  Short offline       Completed without error       00%      7013         -
#13  Short offline       Completed without error       00%      6989         -
#14  Short offline       Completed without error       00%      6965         -
#15  Extended offline    Completed without error       00%      6914         -
#16  Short offline       Completed without error       00%      6893         -
#17  Short offline       Completed without error       00%      6869         -
#18  Short offline       Completed without error       00%      6845         -
#19  Short offline       Completed without error       00%      6821         -
#20  Short offline       Completed without error       00%      6797         -
#21  Extended offline    Completed without error       00%      6747         -
1 of 1 failed self-tests are outdated by newer successful extended offline self-test # 1
So that's the full smartctl -a /dev/ada1 | more output. The second extended SMART test passed, so where does that leave me? Is the drive failing or did it just have a funny few minutes? Setting up SSH is something I have been meaning to do.. this may convince me to get round to setting it up and making sure it's secure
Bidule0hm
Server Electronics Sorcerer
The drive has (at least) one crappy sector. Just bad enough to trigger a read error but not bad enough to be reallocated. See the description text of the ID #197 on this table ;)
At your place I would keep an eye on this drive.
George51
Okay so to bring this thread back - Since this error, I've had no issues with the drive. Until yesterday morning; I got this email
"This message was generated by the smartd daemon running on:
host name: freenas
DNS domain: local
Device info:
No additional messages about this problem will be sent."
So to start with I thought it was a different drive, until I pulled up this old thread again. Realised it was the same one, The results of "smartctl -a /dev/ada1 | more" this time round are as below:
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Local Time is:    Sun Apr 19 08:56:01 2015 BST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  3 Spin_Up_Time            0x0027   135   131   021    Pre-fail  Always       -       4225
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       40
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       8280
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       40
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       9
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       99
194 Temperature_Celsius     0x0022   116   102   000    Old_age   Always       -       27
No Errors Logged
# 1  Extended offline    Completed: read failure       40%      8254         1219691232
# 2  Short offline       Completed without error       00%      8234         -
# 3  Short offline       Completed without error       00%      8210         -
# 4  Short offline       Completed without error       00%      8186         -
# 5  Short offline       Completed without error       00%      8162         -
# 6  Short offline       Completed without error       00%      8138         -
# 7  Extended offline    Completed without error       00%      8087         -
# 8  Short offline       Completed without error       00%      8066         -
# 9  Short offline       Completed without error       00%      8042         -
#10  Short offline       Completed without error       00%      8018         -
#11  Short offline       Completed without error       00%      7994         -
#12  Short offline       Completed without error       00%      7970         -
#13  Extended offline    Completed without error       00%      7920         -
#14  Short offline       Completed without error       00%      7898         -
#15  Short offline       Completed without error       00%      7874         -
#16  Short offline       Completed without error       00%      7851         -
#17  Short offline       Completed without error       00%      7827         -
#18  Short offline       Completed without error       00%      7803         -
#19  Extended offline    Completed without error       00%      7753         -
#20  Short offline       Completed without error       00%      7732         -
#21  Short offline       Completed without error       00%      7708         -
Is this drive getting worse? I am not comfortable reading/interpreting the SMART results. So far this time round, I haven't run anything. By default I do weekly long tests, and daily short tests. As well as monthly scrubs.
Well, the SMART test failed, so it should qualify for an RMA.
James S
We need a bit more clarity here. Could an expert please apply their minds?
(1) Agreed it has passed SMART. It says so.
(2) It has (a) read failure(s). A "read railure"
What does this sum to, though, in terms of say Freenas (and ZFS) in relation to say other systems?
Is it a disk that is really about to fail or is it just now performing well enough for ZFS?
No:
Unless you enjoy philosophical discussions about the existence of data once it was stored by cannot be read... A bad disk.
James S
Yes - "to be or not to be data" isn't going to help much ;)
The point is how to make sense of:
"SMART overall-health self-assesment test result: PASSED"
but
then a "read failure"
SMART overall-health is just about the SMART attributes, it will only fail if one or more attributes are failing NOW, it doesn't even consider for example a few pending secters, not a good way to access a disk health, SMART extended test is a much better way of determining if a disk is good or not, sometimes together with analyzing some SMART attributes.
James S
Johnnie Black - thanks.
I'm wrestling with the the fact the 3 and potentially 4 disks in my system have gone bad. I'm posting here the results of all SMARTs and Zpool status. I'll also give the hardware profile at the bottom. The system (this particular pool) has been running without obvious glitches for over 6 months before dying in a fairly epic fashion.
I'd really appreciate your view on the disks and whether this really is a horrible batch of disks or whether something in my system could be underlying this mess.
I've attached the smart long test results for the four disks.
This last disk was in the array but it faulted so I burned in a new disk, replaced it and started what I hoped was going to a smooth resilvering process (before the 2nd and then 3rd disk started to give problems). I put this disk in another linux machine to re-run smart (to make sure something weird isn't happening in my FN system.
The result of zpool status shows:
root@freenas:~ # zpool status
  pool: NAS2
state: ONLINE
  scan: scrub repaired 0 in 0 days 02:07:10 with 0 errors on Sun Jul 14 02:07:11 2019
        NAS2                                            ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/01dd6f7b-ccf5-11e3-8e0e-60a44ce69c93  ONLINE       0     0     0
            gptid/024dced5-ccf5-11e3-8e0e-60a44ce69c93  ONLINE       0     0     0
            gptid/02bcb705-ccf5-11e3-8e0e-60a44ce69c93  ONLINE       0     0     0
            gptid/0329aca0-ccf5-11e3-8e0e-60a44ce69c93  ONLINE       0     0     0
errors: No known data errors
  pool: NAS2_data
state: ONLINE
  scan: scrub repaired 0 in 0 days 00:12:45 with 0 errors on Sun Jul 14 00:12:48 2019
        NAS2_data                                       ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/025b0bdd-c146-11e8-9d80-ac1f6b2542fe  ONLINE       0     0     0
            gptid/03993d48-c146-11e8-9d80-ac1f6b2542fe  ONLINE       0     0     0
            gptid/04da7480-c146-11e8-9d80-ac1f6b2542fe  ONLINE       0     0     0
            gptid/063a9ab5-c146-11e8-9d80-ac1f6b2542fe  ONLINE       0     0     0
  pool: VM-Datastore
state: UNAVAIL
status: One or more devices are faulted in response to persistent errors.  There are insufficient replicas for the pool to
        continue functioning.
action: Destroy and re-create the pool from a backup source.  Manually marking the device
        repaired using 'zpool clear' may allow some data to be recovered.
  scan: resilvered 0 in 0 days 00:00:00 with 0 errors on Thu Aug 15 17:42:52 2019
        VM-Datastore                                    UNAVAIL    733    68     0
          mirror-0                                      ONLINE       0     0     0
            gptid/2bb4cca3-bb50-11e9-b818-ac1f6b2542fe  ONLINE       0     0     0
            gptid/f9b84327-aecb-11e8-8fb0-ac1f6b2542fe  ONLINE       0     0     0
          mirror-1                                      DEGRADED  1001   190   523
            gptid/fbc1273f-aecb-11e8-8fb0-ac1f6b2542fe  DEGRADED   284   283   566  too many errors
            gptid/fcc066d2-aecb-11e8-8fb0-ac1f6b2542fe  FAULTED      0 1.18K 2.04K  too many errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:22 with 0 errors on Fri Aug  9 03:45:22 2019
        freenas-boot  ONLINE       0     0     0
          ada5p2    ONLINE       0     0     0
For hardware:
Motherboard: Asus kcma-d8 dual socket
CPU: AMD Opteron 4122 (4 core no threading) x2
RAM: 32Gb Kingston ECC
Raid card: Asus Pike 2008 - running the LSI 2008 chipset in jbod mode
Power: FSP Twins (500w) connected to UPS
HDD: 4 x 2TB WD red (Raidz 2) 4 x 2TB WD red (Raidz 1) 4 x 3TB WD red (stripped mirror) From another another post - it seems I've messed up the config of this.
System disks: 2 x 120Gb Intel SSDs
System: FreeNAS 11.1-U7
  • old da0.txt
  • da2.txt
  • da1.txt
  • da0.txt
They are all failing, some attributes to keep an eye on WD drives are, besides the more common pending and reallocated sectors:
Ideally these should be 0, doesn't mean that a disk with a non zero values on either or both is failing, as long as the extended SMART test completes without error the disk is good, but it's never a good sign, and if they keep increasing disk will likely fail sooner rather than later, when the extended SMART test fails the disk is failing, i.e., there are bad sectors.
P.S. it would be nice the see smartctl -x output for all, there's some more info, including logged errors and max lifetime operating temps.
James S
Thanks for the confirmation and taking time to look.
I am trying to get understand this problem. They are not dead as per smart -- yet - but are on the way to the grave. Yet Freenas has marked two of them as faulted. That renders them essential unusable, I guess?
I see the faults seem to cluster around a short period of time (45x hours). I presume if these were all at same time then it would some physical knock to the system. Otherwise does this just look like a bad batch?
Extra infomation is attached.
  • old da0-x.txt
  • da2-x.txt
  • da0-x.txt
  • da1-x.txt
In fact with cases like these, especially when there aren't pending sectors, it can sometimes happen the bad sectors being intermittent, i.e., if you run a couple of extended tests more it might pass again, and the disk can even be good for some time, but in my experience it's more likely to keep failing or fail again soon.
Historic max temperatures are good, so you either you had bad luck or there was some other external factor at play, like high vibrations, power issues, etc, most likely just bad luck.
James S
Thanks for the input. I've sent the 4 WD drives back under warranty. The 3TiB were replaced with 4TiB. So I don't know if the 3s were known to be troublesome.
nick31
Funny thing, yesterday I enabled SMART testing for all disks in my system. 2 of them are WDC WD30PURX-64P6ZY0 WD Purple 3TB.
They were never used, just powered on for 1-2 years. So all critical SMART data is at 0.
Nevertheless, today I was greeted with the same errors as OP for both drives:
# 1 Short offline Completed: read failure 40% 11115 9655736
# 1 Short offline Completed: read failure 40% 5150 590976
This coincidence makes me think that there are some bugs with firmware and maybe we shouldn't trust the test results. Why would these drives fail the test without any usage?
edit: after further investigation it seems the sectors are bad indeed. i get read errors with sg_verify. glad i didn't use these drives.
