I have been running a FreeNAS install for several months on the hardware in my signature below.
The issues began with a SMART error during a routine scrub of the single ZFS RAIDZ1 Storage volume as follows:
I did not have access to the console at the time since the system was physically remote. Several days later, I attempted to login to the system via the Web GUI which was unreachable. On accessing the console, I noticed the system had hung with a kernel panic, as per the below screenshot:
I hard reset the system, and on first boot was met with the following error, which some research suggested a faulty port or boot drive (which is a Lexar 32GB Jumpdrive S23 USB 3.0):
I rebooted again, planning to switch to verbose mode. This time, the system progressed further and proceeded to import the ZFS volume as follows:
The pool import stayed this way for an hour or so, and then a further kernel panic occurred as follows:
I left the system off overnight, and have rebooted again today. This time, for reasons I don't understand, the system has rebooted successfully.
It is however, showing the following error:
The Volume status still shows the Scrub Status as "In Progress". EDIT: this has now completed last night.
Full details from smartctl:
I am concerned that my system lacks stability given the issues when rebooting last night. I do not have a great deal of experience with FreeNAS and am concerned tinkering too much could compromise my data. Please could someone assist with troubleshooting steps?
- First I would like to iron out the issues with the boot drive (if the above indicates such an issue). I have just taken a backup of the configuration (via General>Save Config) but unfortunately do not have a config-file which pre-dates the above issues.
- Is there anything else I should do to verify the functionality of my boot drive?
- Second, my research suggests I should look to replace the drive if I am receiving SMART errors - it is well within warranty. Is this correct? Is there any other testing I can do?
Overall, I am concerned at both the boot issues and SMART errors occurring at similar times - it suggests there may be some other issue with the system which has led to both problems - is there a way of troubleshooting this in particular?
Please do let me know if any further information or log files are needed to assist.
Device: /dev/ada2, Read SMART Self-Test Log Failed Device: /dev/ada2, Read SMART Error Log Failed Device: /dev/ada2, not capable of SMART self-check Device: /dev/ada2, 1 Currently unreadable (pending) sectors Device: /dev/ada2, failed to read SMART Attribute Data
March 12, 2018, 10:07 p.m. - Device: /dev/ada2, 2 Currently unreadable (pending) sectors
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: western digital Red Device Model: WDC WD40EFRX-68N32N0 Serial Number: WD-WCC7K5FL873K LU WWN Device Id: 5 0014ee 26407a93b Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Mon Mar 12 23:05:44 2018 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (44160) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 468) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 154 143 051 Pre-fail Always - 2135 3 Spin_Up_Time 0x0027 177 177 021 Pre-fail Always - 6108 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 10 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 5522 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 10 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 5 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 9 194 Temperature_Celsius 0x0022 121 115 000 Old_age Always - 29 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 2 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 199 199 000 Old_age Offline - 616 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 5376 - # 2 Extended offline Completed without error 00% 5352 - # 3 Extended offline Completed without error 00% 5016 - # 4 Extended offline Completed without error 00% 4704 - # 5 Extended offline Completed without error 00% 4609 - # 6 Extended offline Completed without error 00% 4273 - # 7 Extended offline Completed without error 00% 3961 - # 8 Extended offline Completed without error 00% 3865 - # 9 Extended offline Completed without error 00% 3529 - #10 Extended offline Completed without error 00% 3218 - #11 Extended offline Completed without error 00% 3146 - #12 Extended offline Completed without error 00% 2810 - #13 Extended offline Completed without error 00% 2498 - #14 Extended offline Completed without error 00% 2402 - #15 Extended offline Completed without error 00% 2066 - #16 Extended offline Completed without error 00% 1754 - #17 Extended offline Completed without error 00% 1682 - #18 Extended offline Completed without error 00% 1347 - #19 Extended offline Completed without error 00% 1035 - #20 Extended offline Completed without error 00% 939 - #21 Extended offline Completed without error 00% 603 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing
