Slow speed of FC between TrueNAS and ESXi
daftu
dear community, I've problem with problem in achieving satisfactory speeds between TrueNAS and ESXi using FibreChannel.
My setup:
- HP dl380e G8 with Qlogic ISP 2532 PCI FC-AL Adapter (single port 8Gbit) inserted into PCIe 3.0 8x running TrueNAS
- Dell R630 with Qlogic ISP 2532 PCI FC-AL Adapter (single port 8Gbit) running VMware ESXi 7.0 U1
TN shares two zvol's thru FC which ESXi consumes as a two datastores.
Negotiated speed is 8Gbit:
[root@esxi:~] esxcli storage san fc list
   Adapter: vmhba3
   Port ID: 0000E8
   Node Name: 20:00:00:24:ff:10:3f:23
   Port Name: 21:00:00:24:ff:10:3f:23
   Speed: 8 Gbps
   Port Type: PTP
   Port State: ONLINE
   Model Description: PCI-Express Single Channel 8Gb Fibre Channel HBA
   Hardware Version: PX2810403-78  B
   OptionROM Version: 3.31
   Firmware Version: 8.08.206 (90d5)
   Driver Name: qlnativefc
   DriverVersion: 4.0.3.0
LED indicator on both FC cards are yellow (which means 8Gbit).
Locally tested on TN zpool write speeds are about 350MB/s and read speeds are about 400-500MB/s (non-SSD drives).
From ESXi when reading or writing from single datastore the speeds are quite fine:
#reading from datastore
dd if=/ds1/largefile of=/dev/null bs=1M count=4096
4096+0 records in
4096+0 records out
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 11.3047 s, 380 MB/s
#writing to other datastore
dd if=/dev/zero of=/ds2/largefile bs=1M count=4096
4096+0 records in
4096+0 records out
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 14.2199 s, 302 MB/s
The problem is when I read from one datastore and write to another simultaneously. Both datastore have been tested above for single write/read.
The speed never exceeded 150MB/s and sometimes is about 50-60MB/s.
dd if=/ds1/largefile of=/ds2/largefile bs=1M count=4096
4096+0 records in
4096+0 records out
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 30.5031 s, 110 MB/s
I've replacted the FC patchcord - without any luck.
Is this a normal behavior? Theoretical 8Gbit FC speed is 1GB/sec. I don't know how the duplex works in this case, but let's say it is 500MB/s one direction. Why it is actually so slow balancing about 100MB/s?
Additional FC settings on TN:
# Tunables
ctl_load                 YES
ctladm                     port -o on -t fc
hint.isp.0.fullduplex     1
hint.isp.0.role            0
hint.isp.0.topology        nport-only
ispfw_load                YES
# Task (init command)
