Elliott
- Sep 13, 2019
I'm testing sequential read and write with a single vdev of varous stripe sizes, and I found that write performance scales pretty well. But read performance actually gets worse after 8 disks. I'm trying to figure out what causes this. CPU usage is minimal during reads. I'm currently using FreeNAS 11.3-U1. I ran the same test a few months ago with slightly different hardware on version 11.2 and got much better results. Is there something I can tune to improve this?
For the test, I set compression=off and recordsize=1M. I'm using this script to write 10GB, then export and re-import the pool to clear the ARC, ensuring we are actually reading from the disks. I sync after each write to get the real time.
Here are the results I'm getting in MiB/s
I tested controller bandwidth by running dd to all disks at once and measure 5300MBps combined both read and write like this
I'm using this script to repeat the test:
Machine specs:
FreeNAS 11.3 U1
Dual Xeon 4216
96GB RAM
Disks are Seagate ST10000NM0206. 10TB each, 12G SAS, 7200 RPM connected to LSI 3008 controller.
width write read 1 241 239 2 465 460 4 850 818 8 1429 1205 16 2571 1062 24 2801 872
for i in {0..23}; do dd if=/dev/zero of=/dev/da$i bs=1M count=100000 &; done
for i in {0..23}; do dd of=/dev/null if=/dev/da$i bs=1M count=10000 &; done
# Run with pool name parameter zfs set primarycache=all $1 zfs set compression=off $1 zfs set recordsize=1M $1 echo "Performing write test..." time sh -c "dd if=/dev/zero bs=1M count=10000 of=/$1/ddtest; sync" zpool export $1 zpool import $1 echo "Performing read test..." dd if=/$1/ddtest of=/dev/null bs=1M
Machine specs:
FreeNAS 11.3 U1
Dual Xeon 4216
96GB RAM
