Hello everybody,
I've seen one similar thread but I wasn't able to fix this issue. Read speed on my 5x1TB RAIDZ is much slower than it should be (and two times slower than write):
[root@freenas] ~# dd if=/dev/zero of=/mnt/RAID/tmp.000 bs=1M count=50k
51200+0 records in
51200+0 records out
53687091200 bytes transferred in 169.153484 secs (317386849 bytes/sec)
[root@freenas] ~# dd if=/mnt/RAID/tmp.000 of=/dev/null bs=1M count=50k
51200+0 records in
51200+0 records out
53687091200 bytes transferred in 370.134838 secs (145047387 bytes/sec)
RAID is 65% full
System specs:
FreeNAS-9.3-STABLE-201506292332
Supermicro X8SAX
Intel(R) Xeon(R) CPU E5530 @ 2.40GHz
24GB ECC RAM
5x1TB WD Red RAIDZ
Intel 4 port server ethernet adapter
Compression Off
atime Off
When system was built (and empty) last year, read speed was over 400MB/s and I'm not sure what's causing such huge drop in performance.
Any help is much appreciated :)
51200+0 records in
51200+0 records out
51200+0 records in
51200+0 records out
RAID is 65% full
System specs:
Supermicro X8SAX
24GB ECC RAM
5x1TB WD Red RAIDZ
Compression Off
atime Off
