Well sort of.
I don't really care if I happen to lose a drive completely as the data is usually backed up.
However I do want to avoid silent corruption and avoid loosing data if just a few pieces of a drive is damaged.
So is it possible to have parity data on the same drive but in a different physical location so that any corruption could be reconstructed by resilvering?
Or is this already happening by just using ZFS by the built in checksum?
I guess you could make a few virtual volumes in ESXi and put it on the same disk but I'm not sure how that would work compared to ZFS actually seeing the drive.
