Would appreciate some expert advice if it isn't too late.
My RAIDz2 array was running a scrub this morning, UK temps are unusually high today and for the first time since building this system I received an alarms that the limit of 37degC had been reached by a number of drives.
11:00am I get a more serious warning.
11:10am, appears that the array has crapped itself
checked array status and it looks bad....
Im due to move country on Friday so don't have time to do much troubleshooting.
Device: /dev/da6 [SAT], Temperature 37 Celsius reached critical limit of 37 Celsius (Min/Max 25/37!)
The volume RAID (ZFS) state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The volume RAID (ZFS) state is UNAVAIL: One or more devices are faulted in response to IO failures.
[admin@freenas] /% zpool status
  pool: RAID
state: UNAVAIL
status: One or more devices are faulted in response to IO failures.
action: Make sure the affected devices are connected, then run 'zpool clear'.
   see: http://illumos.org/msg/ZFS-8000-JQ
  scan: scrub in progress since Wed Jul  1 04:00:03 2015
        10.6T scanned out of 20.4T at 422M/s, 6h47m to go
        0 repaired, 51.84% done
    RAID                                            UNAVAIL      0     0     0
     raidz2-0                                      UNAVAIL      0     3     0
       gptid/4087080c-3a74-11e4-b9cb-90e2ba382e3c  ONLINE       0     0     0
       gptid/415efb3e-3a74-11e4-b9cb-90e2ba382e3c  FAULTED      7   142     0  too many errors
       3981687536073005009                         REMOVED      0     0     0  was /dev/gptid/42391ba3-3a74-11e4-b9cb-90e2ba382e3c
       gptid/43109c05-3a74-11e4-b9cb-90e2ba382e3c  ONLINE       0     0     0
       6808129795312123271                         REMOVED      0     0     0  was /dev/gptid/43f12866-3a74-11e4-b9cb-90e2ba382e3c
       gptid/44ceabd7-3a74-11e4-b9cb-90e2ba382e3c  FAULTED      6     8     0  too many errors
       gptid/45aecb5f-3a74-11e4-b9cb-90e2ba382e3c  ONLINE       0     0     0
       gptid/4693dff1-3a74-11e4-b9cb-90e2ba382e3c  ONLINE       0     0     0
       16041530080660729023                        REMOVED      0     0     0  was /dev/gptid/477508a3-3a74-11e4-b9cb-90e2ba382e3c
       gptid/48592025-3a74-11e4-b9cb-90e2ba382e3c  ONLINE       0     0     0
errors: 96 data errors, use '-v' for a list
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Wed Jul  1 03:46:06 2015
    NAME                                          STATE     READ WRITE CKSUM
    freenas-boot                                  ONLINE       0     0     0
     gptid/464811d2-cb24-11e4-9959-90e2ba382e3c  ONLINE       0     0     0
errors: No known data errors
[admin@freenas] /% Im due to move country on Friday so don't have time to do much troubleshooting.
