Sickrage Sabnzb move problem
Bruce Wilfong
Member
Hello all, have had my server setup and running for over a year now. I used JRuehlig guide to install: https://www.jruehlig.com/wordpress/installation-configuration-of-freenas-plugins/
Everything was working fine till sometime in January all movies work fine its the TV shows. All of a sudden sickrage shows shows are downloaded, and sab shows they processed correctly but I am not finding them anywhere. Looks like after the move command the file disappears. I recheck to see if any setting changes but everything is same from the guide. Here is sab process record:
[00:36:37] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[00:36:37] [INFO]::MAIN: Checking database structure... [00:36:37] [INFO]::MAIN: Checking if git needs an update [00:36:38] [INFO]::MAIN: There is a newer version available  (you're 157 commits behind) [00:36:38] [INFO]::MAIN: nzbToMedia Version:c50957d0b4683a125df039329d8f90df630d4e28 Branch:master (FreeBSD 10.3-RELEASE) [00:36:38] [INFO]::MAIN: #########################################################
[00:36:38] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[00:36:38] [INFO]::MAIN: Script triggered from SABnzbd
[00:36:39] [INFO]::MAIN: Auto-detected SECTION:SickBeard [00:36:39] [INFO]::MAIN: Calling SickBeard:tv to post-process:pBS.S06E01.720p.HDTV.x264-BATV.nzb
[00:36:39] [INFO]::MAIN: Attempting to auto-detect tv fork
[00:36:39] [INFO]::MAIN: SickBeard:tv fork auto-detection successful ...
[00:36:39] [INFO]::MAIN: SickBeard:tv fork set to sickragetv
[00:36:39] [INFO]::MAIN: FLATTEN: Flattening directory: /mnt/media/downloads/sabnzbd/complete/tv/PBS.S06E01.720p.HDTV.x264-BATV
[00:36:39] [INFO]::TRANSCODER: Checking [10E60S.dnalemoH.mkv] for corruption, please stand by ...
[00:36:39] [INFO]::TRANSCODER: SUCCESS: [10E60S.dnalemoH.mkv] has no corruption.
[00:36:39] [POSTPROCESS]::SICKBEARD: SUCCESS: The download succeeded, sending a post-process request [00:36:39] [POSTPROCESS]::SICKBEARD: Auto post processing task for /mnt/media/downloads/sabnzbd/complete/tv/PBS.S06E01.720p.HDTV.x264-BATV was added to the queue
[00:36:39] [POSTPROCESS]::SICKBEARD: <br\><span class='hidden'>Processing succeeded</span>
[00:36:39] [INFO]::CLEANDIR: Doing Forceful Clean of /mnt/media/downloads/sabnzbd/complete/tv/PBS.S06E01.720p.HDTV.x264-BATV
[00:36:39] [INFO]::MAIN: Deleting /mnt/media/downloads/sabnzbd/complete/tv/PBS.S06E01.720p.HDTV.x264-BATV [00:36:39] [INFO]::MAIN: The /usr/local/share/nzbToMedia/nzbToSickBeard.py script completed successfully. SickBeard: Successfully post-processed PBS.S06E01.720p.HDTV.x264-BATV.nzb!
Bif
Neophyte
I have exactly the same issue, tvshows download->process then just disappear.
Bruce Wilfong
Member
Yes fix it, had to update the nzbToMedia file:
git clone git://github.com/clinton-hall/nzbToMedia.git /usr/local/share/nzbToMedia
