Shutdown via Cron Job: switch is -p or -h?
panz
I'd like to shutdown my FreeNAS server every Monday at 3:00 a.m., so I setup a simple Cron Job like this:
User: Root
Command: shutdown -p now
Redirect Stdout: Checked
Redirect Stderr: Checked
The switch is -p or -h?
Yatti420
That is correct and how I set mine up.. I have to go back through all my cron jobs soon..
Yatti420
Note: If you don't run as root it will fail.. As well as many other crons that need root..
panz
I just tried from a SSH session: the -h switch doesn't power off the machine (as expected), so only the -p switch accomplishes the desired result.
-h halts the box... -p power's off the box if the hardware supports ACPI.
