John Childermass
 - Oct 20, 2016
I'd like to set up Time Machine backups from multiple Macs in my household (two Macs, each with a different user/owner, but this might increase) to my TrueNAS CORE system. I'm running TrueNAS-12.0-U8.1 but am ready to update to 13, especially if that makes any difference to this.
I've found a few older threads, but would like to check what the current advice is, please:
In case it makes a difference: I'd like to configure permissions so that the two users can't see each other's Time Machine backups, and I'd like the option of setting quotas for each Mac's set of backups if needed (even if I might not need to impose quotas immediately).
Also, I couldn't find anything about Time Machine in the TrueNAS CORE documentation, even though there's something in the old FreeNAS documentation. Does it still work OK, and is there any reason it's not there any more, or am I just missing it?
Thank you in advance for any tips!
- Should I create a single dataset for all the Time Machine backups to go in, or one dataset for Mac1, and one for Mac2?
 - Should I create dedicated Time Machine users on the TrueNAS system for the Time Machine backups? i.e. even if I already have configured User1, the owner of Mac1, for general access to storage on the TrueNAS system, should I create a dedicated user like "User1-timemachine" or "Mac1-timemachine" solely for the Time Machine backups from Mac1 (and the same for User2 on Mac2)? Or could I just use the existing general-purpose User1 and User2 credentials?
