SOLVED Shell/SMB/Console hangs when accessing a directory
mcmuller
Hi folks,
I have a strange problem: While pool is fine and zfs-tools not finding any fault, I cannot access one particular directory in this pool. All neighbour directories are fine, but when I try to "ls" or "ls -l" shell hangs, console hangs, smb-share hangs infinite. Tried to move/copy/delete this directory or files inside, but without luck and the sam symtom. Log shows nothing most of the time, but once I could see output like this:
May 16 18:25:05 freenas kernel: task:smbd            state:D stack:    0 pid:3349571 ppid:  7057 flags:0x00000000
May 16 18:25:05 freenas kernel: Call Trace:
May 16 18:25:05 freenas kernel:  __schedule+0x282/0x870
May 16 18:25:05 freenas kernel:  schedule+0x46/0xb0
May 16 18:25:06 freenas kernel:  vcmn_err.cold+0x7e/0x80 [spl]
May 16 18:25:06 freenas kernel:  ? kmem_cache_alloc+0xed/0x1f0
May 16 18:25:06 freenas kernel:  ? sa_cache_constructor+0x23/0x40 [zfs]
May 16 18:25:06 freenas kernel:  ? spl_kmem_cache_alloc+0xaf/0x7c0 [spl]
May 16 18:25:06 freenas kernel:  ? _cond_resched+0x16/0x40
May 16 18:25:06 freenas kernel:  ? mutex_lock+0xe/0x30
May 16 18:25:06 freenas kernel:  ? dmu_buf_set_user_ie+0x55/0x80 [zfs]
May 16 18:25:06 freenas kernel:  zfs_panic_recover+0x6d/0x90 [zfs]
May 16 18:25:06 freenas kernel:  zfs_znode_alloc+0x6df/0x740 [zfs]
May 16 18:25:06 freenas kernel:  zfs_zget+0x1ae/0x260 [zfs]
May 16 18:25:06 freenas kernel:  zfs_dirent_lock+0x365/0x6c0 [zfs]
May 16 18:25:06 freenas kernel:  zfs_dirlook+0x88/0x2c0 [zfs]
May 16 18:25:06 freenas kernel:  ? zfs_zaccess+0x22f/0x430 [zfs]
May 16 18:25:06 freenas kernel:  zfs_lookup+0x246/0x3f0 [zfs]
May 16 18:25:06 freenas kernel:  zpl_lookup+0xc5/0x1e0 [zfs]
May 16 18:25:06 freenas kernel:  __lookup_slow+0x84/0x140
May 16 18:25:06 freenas kernel:  walk_component+0x154/0x1d0
May 16 18:25:06 freenas kernel:  ? path_init+0x1e2/0x3e0
May 16 18:25:06 freenas kernel:  path_lookupat+0x73/0x1c0
May 16 18:25:06 freenas kernel:  filename_lookup+0xaa/0x1b0
May 16 18:25:06 freenas kernel:  ? strncpy_from_user+0x4e/0x140
May 16 18:25:06 freenas kernel:  ? getname_flags.part.0+0x45/0x1a0
May 16 18:25:06 freenas kernel:  vfs_statx+0x74/0x130
May 16 18:25:06 freenas kernel:  ? __fput+0x100/0x240
May 16 18:25:06 freenas kernel:  __do_sys_newfstatat+0x31/0x70
May 16 18:25:06 freenas kernel:  ? exit_to_user_mode_prepare+0x32/0x120
May 16 18:25:06 freenas kernel:  do_syscall_64+0x33/0x80
May 16 18:25:06 freenas kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
May 16 18:25:06 freenas kernel: RIP: 0033:0x7f13b6b8887b
May 16 18:25:06 freenas kernel: RSP: 002b:00007fff291cf9c8 EFLAGS: 00000246 ORIG_RAX: 0000000000000106
May 16 18:25:06 freenas kernel: RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f13b6b8887b
May 16 18:25:06 freenas kernel: RDX: 00007fff291cf9d0 RSI: 0000555fcd81773b RDI: 0000000000000048
May 16 18:25:06 freenas kernel: RBP: 00007fff291cfac0 R08: 0000000000000100 R09: 0000000000000001
May 16 18:25:06 freenas kernel: R10: 0000000000000100 R11: 0000000000000246 R12: 0000000000000000
May 16 18:25:06 freenas kernel: R13: 00007fff291cf9d0 R14: 00007fff291cfc00 R15: 0000555fcd817728
I'm on TrueNAS-SCALE-22.02.1, but problem was there before.
Ideas or steps to take anyone??
Greetings from Portugal,
Gregor
Bl00dWolf
Same here for me.
Only restarting SMB services helps for sometime.
And if you accsess SMB shera via IP, not vai maped network drive, all seems to be ok.
anodos
Sambassador
mapped network drive vs IP access indicates lack of call to dfree for path in question (statfs / statvfs). This means I need to really see full debug.
mcmuller
Can you send me a debug (system->advanced->save debug). I need to see permissions and share configuration.
Thanks for taking care! Just out of curiosity, I disabled smb, restarted the system, ssh'd into the shell, did a 'ls' on the directory in question, which went fine and then did a 'ls -l' wich ended with a console-hang and the following console-message:
2022 May 17 16:56:26 freenas PANIC: inode 99224 has invalid mode: 0xfffe
debug is on the way....
anodos
Sambassador
Recap:
mcmuller was affected by following openzfs issue:
There was a period of time when TrueNAS was potentially impacted a while back. See timeline for commit history / fix in openzfs issue.
He rebooted so that openzfs module was loaded cleanly, then ran following command:
echo 1 > /sys/module/zfs/parameters/zfs_recover
This disabled panicing on reading mode of affected file. Once he did this he was able to identify exact file by running command:
ls -li <dir where file located> | grep <inode number>
Once file identified it may be removed.
