Shell for dummies: running testing & burn-in script
AgedReason
Well, I managed to get myself built. All the smoke stayed where it belonged. FreeNAS is installed and running. I managed to get the SAS2308 firmware updated to version 20. So far, so good. Working with a clean slate.
(Confidence growing.)
- Alright, I think it’s time to do some hardware testing. jgreco has a nice post stickied all about that. Wow! There’s even a script! Let’s get that going.
- Okay, how do I do that? Run the script from shell.
- How do I get it there? Transfer it from USB.
- Okay, how? You still gotta mount it first.
- Right. I’ll just look for some info about that. Plenty of suggestions from various places. The only thing they all have in common is a warning that you can muck your ish up really good if you do it wrong. The commands, however, all seem different depending on who’s saying it.
- Oh, boy. Not feeling much like guessing wrong and crashing good.
- Now what?
(Confidence dropping.)
Me searching the forums and the FreeNAS manual.
GtL7kL69TmbDbVgihk9ZURURA0xiqLJC60Ex3wMkquO5O34KPhqG-5FnXF3xMgydKv7h46UznbWQhbJ0SmQoqVHuLRoxx1SfFBd8TLOACgFjSiNL3eZyWZfTvX2rsew5hoy83m_7ipOR8AodVdER1-SHVb4uNBiY4jUPfSqn6KkoSYOtVzO4lSCdKegl4UXNDnGbvVtskGJgNRaLfpZ_l6yzuGm04QqBNpw_FKHvZqyMghLDny5ONS-IDo6pqBkyAPtp97PZNLpCcXm5zaQAeOBCbw2n2l9rgoRb7w3E8P3mHgjTR5fTb1qNKa-dePhlJq5bf-1wYQgkBshSg3jZfuDaUn7WlnBfegERCF8hZ-JDNKCLHhWg2KNqRRuaZUI9vYtGUaQRxIrd8s9_nRbHNWd6_Mg7THB6dOcBCIO7ry3_su78R1RrzabyO5R1Ola7w294UyG_R6G_v6NZ3dqfLikjw_sjx6T1EqXaJDhcgIphGs_j6QRrVqwOnk3uUji2MVvsrTIdgRcx8yUjcGWi057UCsxERixKI0q3rEeBBlUYITfza9Ho6uLQxaX7lWXTuYj70g=w365-h273-no
Also me searching the FreeBSD manual.
Just due to the sheer volume of information, I could really use some focus. Where should I direct my attention to find the information I need to competently wrangle shell commands, specifically in the context of accomplishing useful FreeNAS tasks (like running the burn-in script - as an example). I'm sure I'll get it eventually, but I'd sure appreciate any head start someone would be willing to share with me.
Thanks
I've read:
https://forums.freenas.org/index.php?threads/building-burn-in-and-testing-your-freenas-system.17750/
https://forums.freenas.org/index.php?threads/how-to-install-scripts.13758/
Re: The script - the easiest way is to have a shared dataset for this kind of thing. Just copy-paste the script to that share, navigate to it in the CLI and run it.
Or copy-paste the script's source code into an editor and save it.
Either one is more intuitive than mounting a USB device.
...but of course, for that to work, you have to have a pool, and a share set up on the pool, which doesn't work so well if you haven't tested your hardware yet. But yes, that's the easiest way to get a script onto the server, since you can do your editing in your native environment, whatever that happens to be.
A slightly less-easy way (but one that doesn't require a pool and share to be set up beforehand) would be this:
  • Turn on SSH on the server, check the boxes for enable root login and enable password login
  • Connect to the server using an appropriate SSH client (for Windows, Putty or Bitvise; for Mac or Linux, ssh from the terminal)
  • run 'nano -w myscript.sh', replacing 'myscript' with whatever you want to call the script
  • Copy and paste the script contents from wherever you find them into the ssh session
  • Ctrl-X to exit nano, Y to save
  • run 'chmod +x myscript.sh' to make it executable
Do not attempt to replace the first two steps with just using the Shell button in the web GUI--although it's better than nothing, it isn't that good, and it likes to eat control characters.
AgedReason
Thanks for all the tips.
So, I gave the SSH client a shot. Not sure what happened. On the plus side, it was nothing catastrophic. On the neg, it was nothing.
Here's what I did and then what it did.
login as: root
root@192.168.1.2's password:
FreeBSD 9.3-RELEASE-p28 (FREENAS.amd64) #0 r288272+f229c79: Sat Dec 12 11:58:01 PST 2015
FreeNAS (c) 2009-2015, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# ls
./ .cshrc .shrc save_sshkeys*
../ .k5login .ssh/ update*
.bash_history .login change_password* updatep1*
.bashrc .profile save_cfg* updatep2*
[root@freenas] ~# nano -w solnet-array-test-v2.sh
GNU nano 2.2.6 File: solnet-array-test-v2.sh
[ Wrote 274 lines ]
[root@freenas] ~# chmod +x solnet-array-test-v2.sh
[root@freenas] ~# solnet-array-test-v2.sh
solnet-array-test-v2.sh: Command not found.
./ .login save_sshkeys*
../ .profile solnet-array-test-v2.sh*
.bash_history .shrc update*
.bashrc .ssh/ updatep1*
.cshrc change_password* updatep2*
.k5login save_cfg*
[root@freenas] ~#
Yes, as @solarisguy says, try ./solnet-array-test-v2.sh. The reason this is necessary is because /root/ isn't part of the default path, so it isn't searched by default when you enter an executable name. The ./ tells explicitly to use the current directory.
AgedReason
DERP.
Thanks.
AgedReason
Woo hoo! Looks like it's doin it's thing. or at least started to.
Thanks everyone. Loving the SSH!
l@e
can someone put the file for download somewhere please
i tried copying it from ssh but apparently some characters added (prob space or eol) and could not make it work.
looked via notepad++ also but can not find what im missing.
thanks
