Shadow Copies not showing up
cshenderson
Been running FreeNAS for 3 years now; shadow copies always worked since I first set it up.
Upgraded to 11.3; re-edited the shares to select shadowcopy2 and make sure the enable checkbox is checked.
Snapshots are all still showing good and on schedule.
My testing has included deliberately changing file and add/deleting folders. Shadow copy not showing for file/folder.. nothing. Just: "There are no previous versions available"
Helpful note, running MS AD, all Win10, share though cifs (SMB).
I have done reboots, smb resets, I even did a config export, new install to 11.3 and config import (then fixed shares again); everything fine except .. no shadow copies.
Everything I see troubleshooting is for older versions.
Even tried aux parameter:shadow:ignore_empty_snaps = false
Any helpful tips here? Am I missing something dumb on my part?
anodos
Sambassador
PM me a debug. We'll figure this out and try to get it sorted before U1 if there's an issue with the new shadow copy module. I may need to schedule a remote session with you if it does indeed appear to be a problem because the module is working correctly in our lab.
anodos
Sambassador
Every time I do a debug I get a Kernal Panic. Debug gets to 76% saving..then dies
Okay. Let's start with the basics. Run the following commands and then PM me the contents of /var/log/samba4.
"testparm -s" > /var/log/samba4/testparm.out
"zfs list -t snap | grep <your dataset name>" > /var/log/samba4/zfslist.out
If you have problems getting the directory directory off your server, try running the command tar -cvzf /mnt/tank/share/samba.tgz /var/log/samba4 where you substitute "/mnt/tank/share" with your share's connectpath. This will put a .tgz file in your share that you can then attach to a PM.
cshenderson
Sent you that stuff in a conversation. Not sure the terminology in use as I have never used this forum before.
cshenderson
While troubleshooting, the problem is seemingly solved.
By removing the shadow_copy2 module from the SMB options, shadow copy started to show up on windows machines.
When running version before 11.2, the shadow module had to be loaded in the options for shadow copy to work.
Unsure if I'm just dumb or missing something everyone else understood - but I don't see this clearly in the manual.
anodos
Sambassador
The new behavior is to just use the checkbox to enable shadow copy support. All snapshots that are using space will be displayed. No further action needed. shadow_copy2 is exposed to provide backwards-compatibility with legacy behavior. I'll probably need to just add a validation error to prevent users from doing both at once.
jenksdrummer
FWIW; just built using 11.3U1; shadow copies were not working. Unchecked the 'enable shadowcopies' checkbox on the share; saved; checked it back...shadow copies are now working and showing snaps.
Edit; inconsistency so far; a share I have which contains a single 3.5TB VHDX file; that I'm doing snaps (for replication), doesn't show a shadow even though there's at least 2. Will do more testing/troubleshooting...
anodos
Sambassador
As a sanity check, make sure you have > 0 space used in the snaps "zfs list -t snap".
jenksdrummer
Actually, it does say 0 used for that 3.4T dataset (ava 3.4T). Surprising, because the UI shows a snap with 3.4T referenced. Also currently running a replication job on that dataset to another 11.3U1 host and it seems to be doing "something" about 1gb of data on a 10gb nic.
anodos
Sambassador
Can you post full output of zfs list -t snap -o name,used | grep <dataset name>?
jenksdrummer
OK, so when the snap is using 0, it doesn't show up in Windows. It does show as a snap-point on FreeNAS. It also doesn't replicate the snap.
Doing pull-replication w/ netcat+ssh. Source shows 4 snaps, destination shows 2 snaps. File was unmodified during the times of the latest 2 snaps; and show 0s.
anodos
Sambassador
Yes, this is a design feature. There is a limit to how many previous versions of a file can be presented to an SMB client. We try to only show relevant ones.
arefin932
Is there a way to force samba to show all the snapshots, even the one with size 0, in Windows Volume Shadow copy? I can see all the hourly snapshots in FreeNas but the Windows Volume Shadow Copy only shows the snapshots with size > 0. I have tried aux parameter:shadow:ignore_empty_snaps = false with no luck. Attached is my SAMBA configuration in FreeNas.
anodos
Sambassador
Why do you need to see all of them? If you need direct access to the shadow copy directory you can just open it in File Explorer.
For instance, if you're sharing /mnt/tank/share as "SMB" and tank/share is a dataset, then you can just navigate to \\<server>\<smb>\.zfs\snapshot. This does not even require snapdir visibility to be enabled.
arefin932
The reason is, even though we are modifying and adding files in that share, the snapshot size always remains 0 . If we export a share from the previous snapshot we can see the files of that point of time but snapshot size between the previous and current snapshot still shows 0. We have users who are updating excel files continuously and they want to restore files to a previous version very often. If all the snaps do not show up in previous version, they can't restore the files to the point they want. I have added at least 2 GB of data in that share on 09/04/2020, but as you see in the attached picture that the snapshot sizes are all 0.
arefin932
Also, when I navigate to \\<server>\<smb>\.zfs\snapshot directory, it is empty. The snapshot sizes are showing all 0.
GEOptic
Hey Guys !!
Any conclusion on this VSS issue? I got the same situation after upgrading to TrueNAS 12u1.
I tried the SnapShot check box trick but it did not work. But I did not stop/start SMB service.
Tks!!
