SFTP Folder Problem
DoulosGeek
FreeNAS-9.3-STABLE-201412142326
I have TLS enabled, and "Always Chroot" checked. When I connect via standard FTP the user can only see his own Home Directory. Yet when I connect using SFTP the user can backtrack ALL THE WAY UP TO THE ROOT of the ZFS Volume.
What am I doing wrong here?
SFTP isn't actually FTP in the common sense. Do not confuse the two. SFTP uses SSH while FTP uses FTP (which is handled by proftp).
DoulosGeek
Is there a way to configure SFTP to behave similarly then? To limit the logged in user to his/her own home directory?
DoulosGeek
I set the user as scponly, yet the user can still login via SFTP and can still browse all the way to root.
D
dlavigne
Guest
Which application are they using? e.g. sftp on a Unix system or something else?
DoulosGeek
Filezilla FTP Client on Windows 7.
D
dlavigne
Guest
It looks like the warning we had in previous docs still applies, even though the configuration is now simpler. I'll add it back to the 9.3 docs:
NOTE: some utilities such as WinSCP can bypass the chroot. This section assumes that users are accessing the chroot using the command line sftp.
