SFP+ to RJ45 connection
JenWest1919
Member
Hi everyone,
I'm pulling my hair out trying to understand how to get to a 10gbe connection.
1) I ordered a Chelsio T520. This uses an SFP+ connection
2) This means I need to have an SFP+ cable to go to whatever router/switch I end up using.
3) Most routers/switches I'm seeing have one SFP+ port, followed by a bunch of gigabit (not 10gbe) ports.
4) The ones that have multiple SFP+ ports don't help, because I'm using Cat6a cable up to my wall jack, followed by my MOBO having a 10gbe RJ45 connection
So... anyone know where I can find a router/switch that has an SFP+ port PLUS actual 10gbe RJ45 ports that doesn't cost ~$1,000?
Or, any other recommendations?
Thank you
Wizened Sage
JenWest1919
Member
Sure they do; just use a SFP+ module with a RJ45 rather than with optics. Something like this: https://www.balticnetworks.com/mikrotik-6-speed-rj-45-module.html
Thank you for the response.
I was looking at these transceivers earlier.
I imagine the only way to do this would be:
SFP to SFP switch
1 transceiver connects NAS to existing 1gbe router (for wifi access)
1 transceiver connects from 10gbe RJ45 port on desktop MOBO, to new 2 outlet wall jack, one of which goes to the SFP port, and the other to the existing router. The 10gbe port on mobo connects to SFP port using transceiver, and the 1gbe port on mobo connects to regular gigabit for internet....
Is this unnecessarily complicated?
Sure wish there was a switch that was just 1 SFP port, with a bunch of 10gbe RJ45 ports :P
Wizened Sage
It sounds like it. Why are you proposing to run the 10G and the 1G ports on your desktop separately? There seem like two relatively simple ways to accomplish what you're wanting:
  • Get a switch with enough SFP+ (note, SFP+ is not the same as SFP) ports to cover the 10G hosts you want to use, and at least one GbE port. Wire it to the rest of your network using the GbE port, connect to the T520 using fiber or a SFP+ DAC, connect to the remaining copper infrastructure using SFP+/RJ45 modules.
  • Alternatively, use a SFP+/RJ45 module in your T520, then use a switch with the desired number of RJ45 10G ports.
l@e
Member
Dont forget to put 2 extra ip for th direct path ws - server
JenWest1919
Member
Thank you for the response!
The struggle seems to be finding a switch/router that fits the requirements.
I think I found a solution, though. Correct me if I am wrong!
NETGEAR Nighthawk Pro Gaming 10 port Gigabit Switch - has two 10gbe ports...
Sorry for sounding dumb asf, but if I connect my router to this switch, that provides internet access to my desktop, yes (as shown in diagram, desktop would be connected to the switch's second 10gbe port)?
Thank you
l@e
Member
Should work.
Just remark of sfpp adapter , check with chelsio support if msa is supported anda that adapter has msa
l@e
Member
but if I connect my router to this switch, that provides internet access to my desktop, yes?
It will perform as it is directly plugged to router for the internet part
jgreco
Resident Grinch
Please be careful with what you say. Many switches and devices may not be able to drive this.
On one hand, 10Gig on Category cable requires substantially more power than your typical SFP+ port is designed to provide. The typical way manufacturers are getting around this is to reduce the allowable cable length. However, specific manufacturers may also be cheating and boosting the power available to SFP+ modules.
On the other hand, these things have some firmware built into them and the switch basically needs a "device driver" that knows how to talk to them. It isn't super-complicated, but devices with SFP+ ports often reject things they don't understand and weren't designed to work with.
There's a lot of room for frustration, disappointment, and failure here.
Wizened Sage
Fair enough--I had the little Mikrotik switch on my mind, which I'm pretty sure would work with that module. But my suggestion to use such a module with the T520 card might not have been practical.
jgreco
Resident Grinch
Yeah, the little 4-port Mikrotik 10G switch, assuming it's compatible with that copper SFP+, well it wouldn't be CHEAP, but it'd work.
Wizened Sage
OTOH, I've had that switch on order for two months, and balticnetworks.com now says they don't expect it to ship until April.
jgreco
Resident Grinch
Sigh. The modern wonderful magic era of networking and computers.
Wizened Sage
the only switches I found supporting SFP+ are upwards of $600 to begin with....
Then really, you haven't been looking, or even paying much attention to other threads you've been involved in. This one's been mentioned to you before:
https://www.balticnetworks.com/mikrotik-4-port-sfp-802-3at-af-switch-l5.html
...and it's $125 (though finding one in stock may be difficult). This one:
https://www.ebay.com/itm/DELL-POWER...Qd:sc:FedExHomeDelivery!31324!US!-1:rk:1:pf:0
...though used, is even less. There's an Aruba switch that @Chris Moore has mentioned a few times that gives you 4x SFP+, 48x GbE for around $150.
Especially if you're willing to look at used gear, there are lots of options well under $600 (indeed, under $100).
JenWest1919
Member
I've looked at these but I've been confused and haven't been entirely sure if they're appropriate for my use-case scenario.
Using that Mikrotik for example -- That would require:
1) An SFP+ cable from the NAS to the switch
2) Cat6a cable, with a transceiver, from the switch to the wall jack
3) Cat6a cable, with a transceiver, from the switch to my router
Is that correct? Referencing my other question in an earlier post -- if I take a Cat6a cable (with transceiver to make the SFP+ connection) and connect my router using that to one of the ports on the switch -- that provides my desktop with internet, right?
Chris Moore
Wizened Sage
You would be better off to go with the Aruba switch that I have and connect one of the 1Gb ports to the router to get internet to everything on the switch, then use SFP+ cabling to connect the switch to both the NAS and the Desktop computer by putting a very reasonably priced SFP+ network card in the Desktop computer. No point in all those conversions.
Chris Moore
Wizened Sage
JenWest1919
Member
Thank you for the responses and information.
That seems doable. I've been Googling and I'm assuming I need OM4 Fiber Optic cable then some SFP+ connectors/wall jacks? That was the downside in my mind of running SFP straight to my desktop, as it's about a 30 foot run and would require getting another new card for the desktop.
Is there a particular advantage to doing things this way versus swapping for an RJ45 Intel (for the NAS), then picking up that 10gbe switch?
Of course I'm impatient and already ordered 50 feet of cat6a, connectors and installation tools last night :p
