Is it problem free to setup on a dell server 2 x ssd boot drives (raid1) and 2 x 14Tb data drives (raid1), setup some VM on the system, then move the setup to a supermicro machine?
The other possible issue would be with network setup--if you manually configured a NIC on the first machine, and the second uses a different NIC (and therefore a different driver), you'll need to reconfigure that.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
