Hey,
Trying to setup the Volume Manager and I'm getting a Database Locked Error...
Here's the log..
This is my first time doing this and I am following a Tutorial provided by LifeHacker...and yeah, this is happening?
Here's the log..
Environment: Software Version: FreeNAS-9.1.0-RELEASE-x64 (dff7d13) Request Method: POST Request URL: http://192.168.0.5/storage/volumemanager/ Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 109. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 165. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 25. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in volumemanager 139. if form.is_valid() and formset.is_valid() and form.done(formset): File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in done 393. volume.save() File "/usr/local/www/freenasUI/../freenasUI/storage/models.py" in save 275. super(Volume, self).save(*args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py" in save 546. force_update=force_update, update_fields=update_fields) File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py" in save_base 650. result = manager._insert([self], fields=fields, return_id=update_pk, using=using, raw=raw) File "/usr/local/lib/python2.7/site-packages/django/db/models/manager.py" in _insert 215. return insert_query(self.model, objs, fields, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in insert_query 1661. return query.get_compiler(using=using).execute_sql(return_id) File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py" in execute_sql 937. cursor.execute(sql, params) File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py" in execute 366. six.reraise(utils.DatabaseError, utils.DatabaseError(*tuple(e.args)), sys.exc_info()[2]) File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py" in execute 362. return Database.Cursor.execute(self, query, params) Exception Type: DatabaseError at /storage/volumemanager/ Exception Value: database is locked
