So I wrote myself a little script that uses
I am aware this might be more of a FreeBSD problem instead of a FreeNAS one, but also sure there are some FreeBSD gurus here that can provide some insights. If anyone is using my script, please also take a look and let me know if you are seeing the same thing as me. Thanks everyone
sesutil locate $disk on
to blink LED of failed disk automatically. I set a cron job to have it run every minute and everything seems to work fine. However, after a week or so the script got hanged because the sesutil locate $disk on
command stuck in D state (uninterruptible wait). Furthermore, every and each new sesutil locate $disk on
will stuck in the same state so append a & would just create a pile of them in the same state. Only a reboot can solve the problem for a while and them it repeats.I am aware this might be more of a FreeBSD problem instead of a FreeNAS one, but also sure there are some FreeBSD gurus here that can provide some insights. If anyone is using my script, please also take a look and let me know if you are seeing the same thing as me. Thanks everyone
