ethereal
- Sep 10, 2012
Thank you for taking the time to read my thread. I will give you a little background and hopefully I shall receive some sage advice.
I have used freenas for about 3 years primarily as a media server for television programmes and films. I also used it to backup photographs and home videos.
I had a windows box which i used for editing my photographs and videos. I stored personal documents and computer programs here.
So the windows box had the original photos and videos and i backed them up to the freenas and an external hdd. i thought as i was using ntfs and non ecc memory i may have problems in the future with corruption of my data. so recently i moved my hdd from the windows box to my freenas box. i thought i should keep the new hdd separate. i thought i should keep them separate as this will allow me more hdd fails and i am also backing up the originals and if everything is on one pool i would loose my originals and backups.
1. i did have a zpool (6 x 3 TB Raid-Z2) called freenas.
2. now i have another zpool (4 x 1 TB-Raid-Z1) called working.
the originals are on working and i back these up to freenas
I know that almost all my originals and backups are in the same case is this a problem ?
i thought if all the hdd were together using zfs and ecc memory this would be the best plan
I have a backup on an external hdd and some bluray discs
