1. My use case is mostly storage and backup for the family.
2. Offsite Backup for a small business from a Synology NAS.
3. Apps: Nextcloud, Collabora, Paperless-ngx
* My priority is reliability, stability and safety, storage capacity is currently enough. I'm also considering renting Hetzner offsite storage as an additional backup.
* My ISP delivers 100Mbit/s down and 20Mbit/s up. I think this is the bottleneck of the system (my family members are not in the same household) but preferably I want decent APP performance.
I bought a used (was never really in use) Server consisting of:
Additionally, I have a home server I can salvage:
From the documentation and forum, I thought I use the 8 Drives in 1 RAID-Z2 Pool.
From there, I am not sure how to use my available hardware efficient.
1. Should I use the two Intel SSD's for ZIL/SLOG?
2. Use the 2 Kingston SSDs (mirror) or just the M.2 Slot for boot (stripe).
3. Move the hardware over to the new NAS? Considering the higher reliability and better features (IPMI) as well as power consumption, I think this is the way to go.
I could use the M.2 or the PCIe Slot on the main board to expand my SATA ports for the drives from my old Server. My Router supports 2.5GB/s only but could aggregate two LAN ports on the main board or use the 2.5GB NIC I have in my old server.
Every help and criticism is appreciated.
Best Fabian
Board: A2SDi-8C-HLN4F
RAM: 2x Kingston Premier 32GB DDR4 ECC
Disks: 8x4TB Ironwolf
SSD: 2x1TB Intel D3-S4610
SSD: 2x120GB Kingston A400
NIC: 1x2.5 GB/s
Disks: 2x WD Red Plus
NVme: 2x500GB Samsung 980 Pro
Best Fabian
