Security issue?
andyclimb
On my freenas machine it is possible to hit 9 to enter the shell. You then immediately enter the shell as root and have access to the entire machine. This is a bit less than desirable. Can this feature be disabled, or at least be password protected?
Thanks
Andrew
D
dlavigne
Guest
Uncheck "Enable Console Menu" in System -> Settings -> Advanced.
andyclimb
Thank you very much, I had wondered what that option did!
