SubnetMask
- Jul 27, 2017
I've done some searching, with the latest thread I saw being from 2017, and the general consensus was that using SD cards isn't recommended. The two reasons I've seen mentioned are performance and reliability. As far as performance, how fast does the boot volume really need to be? If USB sticks will work, I'd think modern SD cards should be plenty fast enough. In terms of reliability, SD cards are generally quite reliable, except in high write situations, where they can use up their write endurance pretty quick - I've killed more than one or two that way in Raspberry Pi setups. But these days there's an answer to that: Sandisk High Endurance and Max Endurance cards. Take the 64GB Variants - the High endurance is rated for 5,000 hours of full HD recording and the Max Endurance is rated at 30,000 hours - Somehow I doubt FreeNAS/TrueNAS would come even close to writing that much to the boot media.
What is the thought of the experts with the introduction of these high endurance SD cards since the last thread I saw that was from before these cards existed?
