I have been having difficulty getting my amazon bridge to run inside a jail...after plugging away at it, i have finally got it working.
I now want it to start on jail startup.
I created a script echo_bridge in /etc/rc.d
I set the echo_bridge_enable="YES" in rc.conf
I tested /etc/rc.d/echo_bridge rcvar and it returned
It is listed in rcorder
but upon restart, it doesn't work. if I type tail /var/log/messages i get
but it isn't running
It runs manually when i type /etc/rc.d/echo_bridge start
when i type tail /var/log/messages after manually starting it, I get
Notice the last four lines, which do not appear on restart
Any thoughts?
#!/bin/sh
#PROVIDE echo_bridge
. /etc/rc.subr
name="echo_bridge"
rcvar=echo_bridge_enable
start_cmd="${name}_start"
stop_cmd=":"
echo_bridge_start(){
. /media/echo/echo.sh
load_rc_config $name
run_rc_command "$1"
# echo_bridge # echo_bridge_enable="YES" # (default: "")
Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: rc_startmsgs is set to YES. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: run_rc_command: doit: /usr/sbin/cron -s Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: run_rc_command: doit: pkg_start Feb 7 08:57:46 Automation root: /etc/rc.d/sysctl: DEBUG: run_rc_command: doit: sysctl_start last Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: kern_securelevel_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: inetd_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: ftpd_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: ftpproxy_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: echo_bridge_enable is set to YES. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: run_rc_command: doit: echo_bridge_start
Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: kern_securelevel_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: inetd_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: ftpd_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: ftpproxy_enable is set to NO. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: checkyesno: echo_bridge_enable is set to YES. Feb 7 08:57:46 Automation root: /etc/rc: DEBUG: run_rc_command: doit: echo_bridge_start Feb 7 09:07:15 Automation root: /etc/rc.d/echo_bridge: DEBUG: checkyesno: echo_bridge_enable is set to YES. Feb 7 09:07:15 Automation root: /etc/rc.d/echo_bridge: DEBUG: run_rc_command: doit: echo_bridge_start Feb 7 09:10:13 Automation root: /etc/rc.d/echo_bridge: DEBUG: checkyesno: echo_bridge_enable is set to YES. Feb 7 09:10:13 Automation root: /etc/rc.d/echo_bridge: DEBUG: run_rc_command: doit: echo_bridge_start
Any thoughts?
