nasnice
- Jul 14, 2014
Hi all,
I am currently in the process of building a new NAS and was doing the hard drive burning in procedure per our forum guide.
Encountered some strange results and since this is my first SAS build I am at a loss wat to do...
System is a Non ECC motherboard with the latest Freenas release 11.2-U7. Using a Dell HC310 SAS controller flashed to IT mode and here is my first question.
During startup this controller is identified as follows
So the Firmware is @ level 20 and the driver is 21 is that a problem?
After the first smart test I checked for results and got the following (the output of the smartctl -a/dev/ad0 came in little chunks and took 3 minites to complete...)
This drive is definitely bad or is it?
This is so different from the SATA Smart results that I have problems to interpret this information... what is important... and what not... Looked around but did not find a definite answer... did find many more confused user topics...
Specifically what Correction Algorith invocations mean... is that a normal value?
Thanks in advance for any insights...
Nov 28 06:16:22 freenas mps0: <Avago Technologies (LSI) SAS2008> port 0xe000-0xe0ff mem 0xdf140000-0xdf14ffff,0xdf100000-0xdf13ffff irq 16 at device 0.0 on pci1 Nov 28 06:16:22 freenas mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd Nov 28 06:16:22 freenas mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
Vendor: HGST
Product: HUH728080AL5200
Revision: A907
Compliance: SPC-4
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca2541ac5a8
Serial number: VKGGREHV
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Fri Nov 29 06:38:59 2019 WET
SMART support is: Enabled
Temperature Warning: Enabled
SMART Health Status: OK
Current Drive Temperature: 36 C
Drive Trip Temperature: 85 C
Manufactured in week 21 of year 2018
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 2
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 95805
Seagate Cache Log Sense Failed: Input/output error
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 12950 1.047 0
write: 0 0 0 0 0 0.000 0
verify: 0 0 0 0 19348 0.000 0
Non-medium error count: 0
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background long Failed in segment --> 7 3 7317853072 [0x3 0x5d 0x1]
# 2 Background short Failed in segment --> 6 0 7373601840 [0x3 0x5d 0x1]
Long (extended) Self Test duration: 65535 seconds [1092.2 minutes] This drive is definitely bad or is it?
