ech1965
- Mar 16, 2018
I own a QNAP TS-853A.
* CPU N3150
* 16GB RAM
* 4 HDD 3TO
* 4 HDD 2TO
I'm evaluating 2 setups:
Setup #1 .
* FreeNAS ( 11.2)
* raidz1 4HDD 2to
Setup #2
* Proxmox Native
* MDADM 4x3TO RAID 5
* LVM ( Thin volume for VM) And LV for Storage
* Samba (version 4.9.4) is deployed in a LXC container and storage is visible through mount-bind
I made a few benchmarks ( on the same hardware... kind of multiboot by swapping the USB system disk)
Client:
* Macos Mojave ( signature behaviour modified in /etc/nsmb.conf)
* Freefilesync software used for copying
* Test data ( a bunch of files mainly small files: git repositories...) ( 597MB 6221 Files)
Bench data:
Client -> FreeBSD: 10:42 min for copying the Test Dataset to the NAS
Client -> Proxmox LXC: Less than 6 min for copying the same dataset
Is Zfs that heavier than ext4 for managing small files ?
Ref: content on /etc/nsmb.conf on my macbookpro
* CPU N3150
* 16GB RAM
* 4 HDD 3TO
* 4 HDD 2TO
Setup #1 .
* FreeNAS ( 11.2)
* raidz1 4HDD 2to
Setup #2
* Proxmox Native
Client:
Bench data:
cat /etc/nsmb.conf [default] streams=yes file_ids_off=yes signing_required=no dir_cache_off=yes port445=no_netbios protocol_vers_map=4 signing_req_vers=0
$ cat smb.conf
# smb.conf for samba running in LXC
#======================= Global Settings =======================
[global]
use sendfile = yes
aio read size = 16384
aio write size = 16384
min receivefile size = 16384
write cache size = 262144
strict allocate = yes
allocation roundup size = 4096
fruit:aapl = yes
# Special configuration for Apple's Time Machine
fruit:model = MacPro
fruit:advertise_fullsync = true
## Browsing/Identification ###
workgroup = WORKGROUP
server string = %h server (Samba, Ubuntu)
wins support = yes
local master = yes
preferred master = yes
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = yes
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
server role = standalone server
server min protocol = SMB2_02
server max protocol = SMB3
encrypt passwords = yes
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = never
#======================= Share Definitions =======================
#EC-HOME
[EC]
path = "/shared/EC-HOME"
printable = no
writeable = yes
browseable = yes
access based share enum = no
vfs objects = catia fruit streams_xattr
hide dot files = yes
guest ok = no
ea support = yes
inherit acls = yes
mangled names = no
case sensitive = yes
default case = lower
preserve case = yes
short preserve case = yes
fruit:resource = file
fruit:metadata = netatalk
fruit:locking = netatalk
fruit:encoding = native
[TimeMachineHome]
path = /shared/TIME-MACHINE-HOME/%U
valid users = %U
writable = yes
browseable = yes
durable handles = yes
kernel oplocks = no
kernel share modes = no
posix locking = no
ea support = yes
inherit acls = yes
fruit:time machine = yes
