Benjamin Bryan
- Apr 4, 2014
I've been testing FreeNAS and I'm getting slower than expected write performance under Samba.  Large file transfers are stuck at 65Mbps.  Client and ZFS server are both using Intel nics.  I would blame my hardware but with OmniOS I get 105Mbps writes.  OmniOS and FreeNAS perform the same on NFS so I suspect the issue is with Samba (but I could be wrong).
I'm running FreeNAS 9.2.1.7, all the default settings. Sync=standard, compression=lz4, deduplication=off, atime=off. Same settings for OmniOS. I created a new pool for FreeNAS so it's not an import of the OmniOS pool.
Hardware: Avaton C2750, IBM M1015 HBA, 4GB memory (I doubled the memory to 8GB but it made no difference), 3x250GB 7200 RPM Seagates in RAID-Z, Intel DC S3700 as SLOG.
I tried changing the max Samba protocol at SMB2 and SMB3 but got similar results.
Any suggestions? Thanks.
