FlyingHacker
- Jun 27, 2022
Dell 730xd 6x2 mirrored vdev
TrueNAS Core 13 U1
This is a new build.
I have 22 Windows (8 and 10) client machines all connected via a mapped letter drive. One machine is 10Gig ethernet. The others are 1Gig ethernet, but connect to the server through the same 10 Gig port (all use the same IP). When they all attempt to read the same 965MB file at once some of them somehow fail to read the file. I will try to gather more data on precisely what the error is (the software doesn't report errors directly, but there may be a log I can check next time I do this).
I guess I should add the clients are all READING the file only.
Anyone heard of anything like this?
I don't see much in the server logs other than a TON of these (multiple per second every few minutes):
[2022/07/14 11:25:07.814311, 1] ../../source3/smbd/service.c:357(create_connection_session_info)
create_connection_session_info: guest user (from session setup) not permitted to access this share (MyShare)
[2022/07/14 11:25:07.814377, 1] ../../source3/smbd/service.c:546(make_connection_snum)
I copied the file over to our old Synology NAS (1 Gig only) and everything works fine.
Thanks in advance.
TrueNAS Core 13 U1
Thanks in advance.
