Running FREENAS 9.2.1.8 after upgrading from 9.2.1.7, I am still experiencing some Web GUI error messages or sometime the content of the pane never seem to display its content.
Specs:
FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
Supermicro X10SL7-F (SAS in IT mode)
Intel Xeon E3-1241 v3
Crucial 32GB Unbuffered ECC 1.5v 2 x CT2KIT102472BA160B
6 x WD RED 4TB in RAIDZ2
When displaying my snapshots in WEB GUI and run a filter to isolate specific snapshots, I will get after a few seconds the "Sorry, an error occurred" in the WEB GUI.
At the same time, the message footer will output the following error message:
I tried to run "save debug" from the "System->Setting->Advanced", and I will get the following message to appear in my browser:
I have run the following command found while Googling for the nginx error message and returned the following:
Currently, I have in the following tab "System->Settings->System Dataset" which might have been unchecked in the past:
System dataset pool: WD-RAIDZ2
Syslog: Checked
Reporting Database: Checked.
Note: Just before the upgrade (during that time I already experienced "filesystem full" error messages) I backed-up my config then ran the upgrade procedure.
After reboot, FREENAS was successfully set to 9.2.1.8 but the config was not restored as FREENAS was complaining the file was corrupted. I had to reconfigure FREENAS config from scratch.
All in all, I believe the source cause of the problem is related to the Filesystem. Unforttunately, I do not not how to go by and fix it.
Specs:
pid 36730 (nginx), uid 80 inumber 27884 on /var: filesystem full
<html><head>
<meta http-equiv="content-type" content="text/html; charset=windows-1252"><style type="text/css"> #fi #fic {margin-right:100px !important} #fi #rh {margin-left:-115px !important;width:95px !important} #fi .rh {display:none !important} body:not(.xE) div[role='main'] .Bu:not(:first-child) {display: none !important} </style></head><body><div id="summary">
<table class="meta">
<tbody><tr>
<th>Request Method:</th>
<td>GET</td>
</tr>
<tr>
<th>Request URL:</th>
<td>https://192.168.0.194/system/debug/</td>
</tr>
<tr>
<th>Software Version:</th>
<td>FreeNAS-9.2.1.8-RELEASE-x64 (e625626)</td>
</tr>
<tr>
<th>Exception Type:</th>
<td>IOError</td>
</tr>
<tr>
<th>Exception Value:</th>
<td><pre>[Errno 2] No such file or directory: u'/mnt/WD-RAIDZ2/.system/ixdiagnose/ixdiagnose.tgz'</pre></td>
</tr>
<tr>
<th>Exception Location:</th>
<td>/usr/local/www/freenasUI/../freenasUI/system/views.py in debug, line 692</td>
</tr>
<tr>
<th>Server time:</th>
<td>Sun, 26 Oct 2014 11:31:30 -0700</td>
</tr>
</tbody></table>
</div>
<div id="traceback">
<h2>Traceback</h2>
<div id="browserTraceback">
</div>
<form action="http://dpaste.com/" name="pasteform" id="pasteform" method="post" target="_blank">
<div id="pastebinTraceback" class="pastebin">
<input name="language" value="PythonConsole" type="hidden">
<input name="title" value="IOError at /system/debug/" type="hidden">
<input name="source" value="Django Dpaste Agent" type="hidden">
<input name="poster" value="Django" type="hidden">
<textarea name="content" cols="120" rows="25" readonly="yes" data-dojo-type="dijit.form.Textarea">Environment:
Software Version: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
Request Method: GET
Request URL: https://192.168.0.194/system/debug/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
107. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
158. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
22. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/system/views.py" in debug
692. wrapper = FileWrapper(file(dump))
Exception Type: IOError at /system/debug/
Exception Value: [Errno 2] No such file or directory: u'/mnt/WD-RAIDZ2/.system/ixdiagnose/ixdiagnose.tgz'
</textarea>
<br><br>
<!-- <input type="submit" value="Share this traceback on a public Web site"> -->
</div>
</form>
</div>
<div id="requestinfo">
<h2>Request information</h2>
<h3 id="get-info">GET</h3>
<p>No GET data</p>
<h3 id="post-info">POST</h3>
<p>No POST data</p>
<h3 id="files-info">FILES</h3>
<p>No FILES data</p>
<h3 id="cookie-info">COOKIES</h3>
<table class="req">
<thead>
<tr>
<th>Variable</th>
<th>Value</th>
</tr>
</thead>
<tbody>
<tr>
<td>csrftoken</td>
<td class="code">'eByOmjz7srVIfqnCif9JOSA5KY32l4M7'</td>
</tr>
<tr>
<td>sessionid</td>
<td class="code">'zly3trkyrsigjzk0jb3wmpa6eup40f43'</td>
</tr>
<tr>
<td>fntreeSaveStateCookie</td>
<td class="code">'root%2Croot%2F223%2Croot%2F47%2F60%2Croot%2F47%2F57%2Croot%2F47%2F53%2Croot%2F10%2F32%2Croot%2F52%2Croot%2F252%2Croot%2F254%2Croot%2F254%2F260%2Croot%2F249%2Croot%2F249%2F255%2Croot%2F249%2F255%2F257%2Croot%2F245%2Croot%2F248%2Croot%2F250%2Croot%2F250%2F256%2Croot%2F250%2F256%2F258%2Croot%2F251%2Croot%2F310%2Croot%2F312%2Croot%2F274%2Croot%2F276%2Croot%2F271%2F277%2Croot%2F271%2F277%2F279%2Croot%2F318%2Croot%2F320%2Croot%2F307%2Croot%2F307%2F313%2Croot%2F307%2F313%2F315%2Croot%2F316%2Croot%2F316%2F322%2Croot%2F316%2F322%2F324%2Croot%2F267%2Croot%2F267%2F274%2Croot%2F314%2Croot%2F314%2F320%2Croot%2F314%2F320%2F322%2Croot%2F421%2Croot%2F464%2Croot%2F466%2Croot%2F466%2F472%2F474%2Croot%2F1%2Croot%2F1%2F6%2Croot%2F305%2Croot%2F637%2Croot%2F635%2Croot%2F619%2Croot%2F10%2F30%2Croot%2F10%2F26%2Croot%2F615%2Croot%2F617%2Croot%2F617%2F623%2Croot%2F475%2Croot%2F467%2Croot%2F467%2F473%2Croot%2F467%2F473%2F475%2Croot%2F309%2Croot%2F10%2F11%2Croot%2F62%2Croot%2F62%2F63%2Croot%2F62%2F248%2Croot%2F62%2F85%2Croot%2F268%2Croot%2F284%2Croot%2F268%2F275%2Croot%2F326%2Croot%2F329%2F335%2F337%2Croot%2F330%2Croot%2F287%2Croot%2F333%2F339%2F341%2Croot%2F336%2Croot%2F336%2F342%2Croot%2F336%2F342%2F344%2Croot%2F276%2F283%2Croot%2F337%2Croot%2F337%2F343%2F345%2Croot%2F332%2Croot%2F334%2Croot%2F337%2F364%2F366%2Croot%2F276%2F280%2Croot%2F280%2Croot%2F280%2F284%2Croot%2F296%2Croot%2F343%2Croot%2F343%2F370%2Croot%2F343%2F370%2F372%2Croot%2F343%2F349%2Croot%2F343%2F349%2F351%2Croot%2F284%2F293%2Croot%2F121%2Croot%2F8%2Croot%2F8%2F32%2Croot%2F1%2F2%2Croot%2F1%2F5%2Croot%2F50%2Croot%2F50%2F51%2Croot%2F264%2Croot%2F52%2F262%2Croot%2F277%2Croot%2F321%2Croot%2F332%2F342%2Croot%2F332%2F346%2Croot%2F332%2F350%2F352%2Croot%2F332%2F338%2F340%2Croot%2F332%2F346%2F348%2Croot%2F10%2F34%2Croot%2F10%2F14%2Croot%2F288%2Croot%2F53%2Croot%2F53%2F267%2Croot%2F10%2F17%2Croot%2F332%2F338%2Croot%2F53%2F60%2Croot%2F351%2Croot%2F351%2F369%2Croot%2F351%2F369%2F371%2Croot%2F351%2F357%2Croot%2F351%2F357%2F359%2Croot%2F334%2F340%2Croot%2F334%2F340%2F342%2Croot%2F333%2Croot%2F333%2F339%2Croot%2F329%2Croot%2F38%2Croot%2F10'</td>
</tr>
</tbody>
</table>
<h3 id="meta-info">META</h3>
<table class="req">
<thead>
<tr>
<th>Variable</th>
<th>Value</th>
</tr>
</thead>
<tbody>
<tr>
<td>wsgi.multiprocess</td>
<td class="code">False</td>
</tr>
<tr>
<td>HTTP_REFERER</td>
<td class="code">'https://192.168.0.194/'</td>
</tr>
<tr>
<td>REDIRECT_STATUS</td>
<td class="code">'200'</td>
</tr>
<tr>
<td>SERVER_SOFTWARE</td>
<td class="code">'nginx/1.4.4'</td>
</tr>
<tr>
<td>SCRIPT_NAME</td>
<td class="code">u''</td>
</tr>
<tr>
<td>REQUEST_METHOD</td>
<td class="code">'GET'</td>
</tr>
<tr>
<td>PATH_INFO</td>
<td class="code">u'/system/debug/'</td>
</tr>
<tr>
<td>SERVER_PROTOCOL</td>
<td class="code">'HTTP/1.1'</td>
</tr>
<tr>
<td>QUERY_STRING</td>
<td class="code">''</td>
</tr>
<tr>
<td>CONTENT_LENGTH</td>
</tr>
<tr>
<td>HTTP_USER_AGENT</td>
<td class="code">'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:33.0) Gecko/20100101 Firefox/33.0'</td>
</tr>
<tr>
<td>HTTP_CONNECTION</td>
<td class="code">'keep-alive'</td>
</tr>
<tr>
<td>HTTP_COOKIE</td>
<td class="code">'csrftoken=eByOmjz7srVIfqnCif9JOSA5KY32l4M7;
sessionid=zly3trkyrsigjzk0jb3wmpa6eup40f43;
fntreeSaveStateCookie=root%2Croot%2F223%2Croot%2F47%2F60%2Croot%2F47%2F57%2Croot%2F47%2F53%2Croot%2F10%2F32%2Croot%2F52%2Croot%2F252%2Croot%2F254%2Croot%2F254%2F260%2Croot%2F249%2Croot%2F249%2F255%2Croot%2F249%2F255%2F257%2Croot%2F245%2Croot%2F248%2Croot%2F250%2Croot%2F250%2F256%2Croot%2F250%2F256%2F258%2Croot%2F251%2Croot%2F310%2Croot%2F312%2Croot%2F274%2Croot%2F276%2Croot%2F271%2F277%2Croot%2F271%2F277%2F279%2Croot%2F318%2Croot%2F320%2Croot%2F307%2Croot%2F307%2F313%2Croot%2F307%2F313%2F315%2Croot%2F316%2Croot%2F316%2F322%2Croot%2F316%2F322%2F324%2Croot%2F267%2Croot%2F267%2F274%2Croot%2F314%2Croot%2F314%2F320%2Croot%2F314%2F320%2F322%2Croot%2F421%2Croot%2F464%2Croot%2F466%2Croot%2F466%2F472%2F474%2Croot%2F1%2Croot%2F1%2F6%2Croot%2F305%2Croot%2F637%2Croot%2F635%2Croot%2F619%2Croot%2F10%2F30%2Croot%2F10%2F26%2Croot%2F615%2Croot%2F617%2Croot%2F617%2F623%2Croot%2F475%2Croot%2F467%2Croot%2F467%2F473%2Croot%2F467%2F473%2F475%2Croot%2F309%2Croot%2F10%2F11%2Croot%2F62%2Croot%2F62%2F63%2Croot%2F62%2F248%2Croot%2F62%2F85%2Croot%2F268%2Croot%2F284%2Croot%2F268%2F275%2Croot%2F326%2Croot%2F329%2F335%2F337%2Croot%2F330%2Croot%2F287%2Croot%2F333%2F339%2F341%2Croot%2F336%2Croot%2F336%2F342%2Croot%2F336%2F342%2F344%2Croot%2F276%2F283%2Croot%2F337%2Croot%2F337%2F343%2F345%2Croot%2F332%2Croot%2F334%2Croot%2F337%2F364%2F366%2Croot%2F276%2F280%2Croot%2F280%2Croot%2F280%2F284%2Croot%2F296%2Croot%2F343%2Croot%2F343%2F370%2Croot%2F343%2F370%2F372%2Croot%2F343%2F349%2Croot%2F343%2F349%2F351%2Croot%2F284%2F293%2Croot%2F121%2Croot%2F8%2Croot%2F8%2F32%2Croot%2F1%2F2%2Croot%2F1%2F5%2Croot%2F50%2Croot%2F50%2F51%2Croot%2F264%2Croot%2F52%2F262%2Croot%2F277%2Croot%2F321%2Croot%2F332%2F342%2Croot%2F332%2F346%2Croot%2F332%2F350%2F352%2Croot%2F332%2F338%2F340%2Croot%2F332%2F346%2F348%2Croot%2F10%2F34%2Croot%2F10%2F14%2Croot%2F288%2Croot%2F53%2Croot%2F53%2F267%2Croot%2F10%2F17%2Croot%2F332%2F338%2Croot%2F53%2F60%2Croot%2F351%2Croot%2F351%2F369%2Croot%2F351%2F369%2F371%2Croot%2F351%2F357%2Croot%2F351%2F357%2F359%2Croot%2F334%2F340%2Croot%2F334%2F340%2F342%2Croot%2F333%2Croot%2F333%2F339%2Croot%2F329%2Croot%2F38%2Croot%2F10'</td>
</tr>
<tr>
<td>SERVER_NAME</td>
<td class="code">'localhost'</td>
</tr>
<tr>
<td>REMOTE_PORT</td>
<td class="code">'50350'</td>
</tr>
<tr>
<td>wsgi.url_scheme</td>
<td class="code">'https'</td>
</tr>
<tr>
<td>SERVER_PORT</td>
<td class="code">'443'</td>
</tr>
<tr>
<td>SERVER_ADDR</td>
<td class="code">'192.168.0.194'</td>
</tr>
<tr>
<td>DOCUMENT_ROOT</td>
<td class="code">'/usr/local/etc/nginx/html'</td>
</tr>
<tr>
<td>DOCUMENT_URI</td>
<td class="code">'/system/debug/'</td>
</tr>
<tr>
<td>wsgi.input</td>
<td class="code"><flup.server.fcgi_base.InputStream object at 0x80ac89b90></td>
</tr>
<tr>
<td>HTTP_DNT</td>
<td class="code">'1'</td>
</tr>
<tr>
<td>HTTP_HOST</td>
</tr>
<tr>
<td>HTTPS</td>
<td class="code">'on'</td>
</tr>
<tr>
<td>wsgi.multithread</td>
<td class="code">True</td>
</tr>
<tr>
<td>REQUEST_URI</td>
</tr>
<tr>
<td>HTTP_ACCEPT</td>
<td class="code">'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'</td>
</tr>
<tr>
<td>wsgi.version</td>
<td class="code">(1, 0)</td>
</tr>
<tr>
<td>GATEWAY_INTERFACE</td>
<td class="code">'CGI/1.1'</td>
</tr>
<tr>
<td>wsgi.run_once</td>
</tr>
<tr>
<td>wsgi.errors</td>
<td class="code"><flup.server.fcgi_base.TeeOutputStream object at 0x8130de990></td>
</tr>
<tr>
<td>REMOTE_ADDR</td>
<td class="code">'192.168.0.192'</td>
</tr>
<tr>
<td>HTTP_ACCEPT_LANGUAGE</td>
<td class="code">'en-US,en;q=0.5'</td>
</tr>
<tr>
<td>CONTENT_TYPE</td>
</tr>
<tr>
<td>CSRF_COOKIE</td>
<td class="code">u'eByOmjz7srVIfqnCif9JOSA5KY32l4M7'</td>
</tr>
<tr>
<td>HTTP_ACCEPT_ENCODING</td>
<td class="code">'gzip, deflate'</td>
</tr>
</tbody>
</table>
</div>
</body></html>I have run the following command found while Googling for the nginx error message and returned the following:
df -h /var Filesystem Size Used Avail Capacity Mounted on /dev/md2 149M 148M -11M 108% /var
Syslog: Checked
