Hi all
My backupserver:
FreeNAS Build FreeNAS-8.0.2-RELEASE-i386 (8288)
Platform Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Memory 2537MB
OS Version FreeBSD 8.2-RELEASE-p3
My ms6 server :
Platform: Intel(R) Core(TM) i3-2100T CPU @ 2.50GHz (2494.36-MHz K8-class CPU)
Memory: 4096 MB
On backupserver I set rsync daemon with this conf:
[root@backup] ~# cat /usr/local/etc/rsyncd.conf
use chroot = yes
max connections = 4
pid file = /var/run/rsyncd.pid
[ms6]
comment = ms6 server
path = /mnt/data/ms6
max connections = 0
uid = root
gid = wheel
read only = false
write only = false
[root@backup] ~# mount
/dev/ufs/FreeNASs1a on / (ufs, local, read-only, soft-updates)
devfs on /dev (devfs, local, multilabel)
/dev/md0 on /etc (ufs, local)
/dev/md1 on /mnt (ufs, local)
/dev/md2 on /var (ufs, local)
/dev/ufs/FreeNASs4 on /data (ufs, local, noatime, soft-updates)
data on /mnt/data (zfs, local)
On my server (ms6) I use something like:
rsync -avp --delete /usr/local/jails/ backupserver::ms6
After one minute of sync (a lot of file need to be synced)
the backupserver make a boooom! with this message:
https://p.twimg.com/AhBOxjxCEAAw7Pz.jpg
(every time I try to do sync)
ms6 server and backup server ram is ok
each server have gigabit link to same HP L2 procurve switch
Where is the problem?
kind regards
My backupserver:
Memory 2537MB
My ms6 server :
Memory: 4096 MB
use chroot = yes
max connections = 4
[ms6]
max connections = 0
uid = root
gid = wheel
read only = false
write only = false
kind regards
