TempleHasFallen
- Jan 27, 2022
After going through tons of troubleshooting steps, this is what I have gathered that apps with external interfaces (ex. IP on LAN), by default route the traffic through the internal kubernetes NIC.
I've tried setting routes via the GUI, but it does not affect the default route (unless you know exactly the IPs/subnets you're going to be connecting to).
Assuming you don't want all apps to use your NAS IP, there are various ways this can be achieved, I'm looking for better solutions at the moment.
Script Inside Container, post init
Basically an entrypoint script which is executed and modifies the default route.
This requires the "NET_ADMIN" capability which needs to be added either via GUI or via k3s kubectl.
This is described in this thread.
I wasn't able to replicate it due to my pod erroring out with regardless of if my app was configured with NET_ADMIN, SYS_ADMIN, NET_RAW, privileged mode (or any combination of those)
Script on Host, on demand
Best I've come up with is a script which can be run on demand and ideally post system init (with delay) to modify the default route of apps to match their external interface.
This also works for containers that don't have installed.
If anyone has any more efficient/automated/better ideas, please share your ideas.
ip: rtnetlink answers: operation not permitted
ip
#!/bin/sh for container in app1 app2 app3 app4 do conid='' conpid='' conid=$(docker ps | grep k8s_$container | awk 'NR==1{print $1}') conpid=$(docker inspect --format '{{.State.Pid}}' "$conid") if [ ! -z "$conpid" ] then nsenter -n -t "$conpid" ip route del default nsenter -n -t "$conpid" ip route add default via 192.168.1.1 dev net1 echo "Added route for $container" fi done
