sqwob
- Jan 8, 2013
situation: I had 8.3.0 p1 running for almost a year when my usb stick decided that it was time to corrupt some data. Unable to boot from it from this point on I reinstalled it with what I believed was the same version.
Turns our however that i didn't install 8.3.0 but 8.3.1 instead. I uploaded the configuration file after setting the network configuration and everything seems to have worked like a charm. No issues so far (Iscsi works, network shares & permissions are all good. jails/sabnzb etc also work.)
Should i worry about this unexpected upgrade and consider downgrading, or can i assume it's safe to continue using my current install?
Kind regards
Rik
Kind regards
Rik
