-fun-
 - Oct 27, 2015
I want to create a new pool on a disk which has an unused pool on it. (I migrated all my data from there to a new pool a while ago. The existing pool was just detached without destroying anything.)
What is the easiest way to do this?
I first tried to simply create a new pool on this disk but failed:
I then tried to wipe the disk:
I would have imported the old pool and then detached it with the destroy option. But I didn't dare to do this because it has the same name as an existing pool in my system.
After this I checked the guide to no avail.
Finally I'm here ...
EDIT: My Solution. FreeNAS was using the drive as swap device. I used
 [MiddlewareError: Unable to GPT format the disk "ada2": gpart: geom 'ada2': File exists]I then tried to wipe the disk:
 [MiddlewareError: Failed to wipe ada2p1: dd: /dev/ada2p1: Operation not permitted]I would have imported the old pool and then detached it with the destroy option. But I didn't dare to do this because it has the same name as an existing pool in my system.
 gmirror list to identify which swap device was using the disk (in my case 'Name: mirror/swap0'). I determined the device name using  swapinfo and found '/dev/mirror/swap0.eli' and deleted this using  swapoff /dev/mirror/swap0.eli. (Note: I had to free memory to get this done because FreeNAS must relocate used swap space somewhere else. This should be easy after a reboot of FreeNAS.) After this I could wipe the disk (quick option didn't work, wiping with zeroes did work). After the wipe I could create a volume on the disk. The swap device got recreated automatically.
