I had a drive in a pool which started throwing checksum errors, so I decided to initiate a replace with a spare from the GUI.
The resilvering process has been running for almost two days, (it's a 1TB drive), which I guess is to be somewhat expected. However, whenever I check the status it keeps fluctuating up and down. Below for example is the current status:
These numbers keep moving up and down. For example, right now it is at 5.33% with 40.4G resilvered, but earlier this morning it was
107G resilvered, 14.04% done. And yesterday there was a similar pattern, with the status numbers moving up and down. This of course logically seems odd- one would expect the number to gradually increase toward 100%, even if slowly.
I also note that the timestamp of the resilver process starting also changes. For example now it says "resilver in progress since Sun Apr 26 12:13:17 2020", but when I checked this morning it stated "resilver in progress since Sun Apr 26 09:32:46 2020". In fact I actually started the replacement process late on Friday night. This leads me to believe that the resilvering process keeps perhaps re-starting?
Is there a reason to expect the process to restart and/or the numbers to go down as opposed to gradually up, or is this indicative of some other problem? Are there any detailed logs written by the resilvering process that I could check for potential issues?
Version is FreeNAS-11.1-U7 (I know it's old- was planning to upgrade once this array problem is resolved in order to reduce the number or variables at play).
Thanks in advance for any ideas.
root@freenas:~ # zpool status external-tank-01 pool: external-tank-01 state: DEGRADED status: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state. action: Wait for the resilver to complete. scan: resilver in progress since Sun Apr 26 12:13:17 2020 1.90T scanned at 2.60G/s, 244G issued at 333M/s, 4.46T total 40.4G resilvered, 5.33% done, 0 days 03:41:46 to go config: NAME STATE READ WRITE CKSUM external-tank-01 DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 replacing-0 DEGRADED 0 0 33.3K da5p2 DEGRADED 0 0 0 too many errors gptid/16b1571d-86fb-11ea-bb2b-001517acd8c9 ONLINE 0 0 0 (resilvering) gptid/702d0621-e9fc-11e9-9ee0-001517acd8c9 ONLINE 0 0 0 gptid/71121431-e9fc-11e9-9ee0-001517acd8c9 ONLINE 0 0 0 gptid/720e10fe-e9fc-11e9-9ee0-001517acd8c9 ONLINE 0 0 0 gptid/72f36ff2-e9fc-11e9-9ee0-001517acd8c9 ONLINE 0 0 0 gptid/7681e9dd-e9fc-11e9-9ee0-001517acd8c9 ONLINE 0 0 0 errors: No known data errors
