my hypervisior (proxmox) creates every day a full backup file of each of my VMs.
If I know set up a replication task between 2 freenas boxes, does zfs replication understand that the data is more or less the same even if the filename is different?
I don't want to transfer every day 600GB it just few MB are changed...
My procedure how I think about it would be:
Hypervisor create backupfiles on a nfs share ("actual backup dataset") on the first freenas box.
A replication task copies data to the second freenas box.
All backup files moved to an archiv dataset, so "actual backup dataset" is empty.
Next Day:
Hypervisor create new backupfiles on nfs share ("actual backup dataset") on the first freenas box.
A replication task copies only incremental data to the second freenas box.
All backup files moved to the archiv dataset, so "actual backup dataset" is empty.
And so on the next days...
Am I thinking to "easy"?
Next Day:
