SOLVED Replication Task stuck 'Running'
Metheos
I have a couple of replication tasks that are stuck showing 'Running' on the source machine. Version: FreeNAS-11.3-U3.1
Checking for running processes and network activity show nothing related to these replication tasks on the source or target servers.
Is there some way to clear the 'Running' state on these jobs so they can be started again?
NasKar
It maybe it's replicating a large dataset so its taking a long time. If you run zfs list on the source it will tell you the size of the dataset and then you can run it on the destination to see where it's at.
Metheos
There does not appear to be any running zfs or ssh tasks or network activity on the receiving end.
Metheos
I tried deleting one of the stuck tasks, which it let me do suprisingly... Then I recreated the task, but when I run it i get this message in the logs:
 can't execute in parallel with already running tasks, delaying it
I set up a 'pull' replication task on the remote side for the same data and it worked without issue. I can't set the option to hold pending snapshots doing it this way though, so I'd still like to find a solution to clear whatever has the replication service convinced there is something replicating.
Metheos
If anyone runs into this in the future, I was able to unstick it by running
midclt call zettarepl.stop
midclt call zettarepl.start
This apparently cleared up whatever the blockage was.
CheeryFlame
Doesn't work on Scale in 2023.
