VulcanRidr
 - Jan 5, 2015
I set up three replication tasks on my FreeNAS box. I have two pools on my FreeBSD desktop machine, and one on my laptop (both running 12.1p3)...And immediately ran into a problem. In the FreeNAS GUI, I set up I set up ssh keys, ssh connections, then set up my replications to the three datasets. I chose "Run Now" to make sure it worked. After I did that, the replication started failing, and I started getting errors in the FreeNAS logs like
collectd[2155]: statfs(/mnt/NX80101) failed: No such file or directory
For each and every dataset on the system. And the replications started failing at their scheduled times. When I set the replication up, I had each pool do recursive replication from the top-level dataset to my FreeNAS. I set up a dataset called "archive", then under that, a separate dataset for each replication task.
So when I checked my /mnt directory, and instead of it looking like
It looked like
Which looks suspiciously like the root filesystem on my laptop. Can anyone explain what happened and how I can set up repplication? I have deleted those datasets and disabled the replication until I get this sorted out.
Thanks,
root@luna:~ # ls -l /mnt total 21 -rw-r--r-- 1 root wheel 5 Apr 9 15:51 md_size drwxr-xr-x 16 root wheel 16 Apr 8 09:44 NX80101
It looked like
root@luna:~ # ls -l /mnt total 188 -rw-r--r-- 2 root wheel 951 Nov 8 14:59 .cshrc drwx------ 3 root wheel 3 Jan 22 2019 .dbus -rw-r--r-- 2 root wheel 470 Nov 8 14:59 .profile drwxr-xr-x 2 root wheel 46 Apr 12 11:48 bin drwxr-xr-x 10 root wheel 63 Apr 12 14:53 boot -r--r--r-- 1 root wheel 6181 Nov 8 14:59 COPYRIGHT drwxr-xr-x 2 root wheel 2 Jan 22 2019 dev -rw------- 1 root wheel 4096 Apr 12 14:54 entropy drwxr-xr-x 25 root wheel 110 Apr 7 00:03 etc lrwxr-xr-x 1 root wheel 8 Jan 22 2019 home -> usr/home drwxr-xr-x 2 root wheel 2 Mar 5 2019 justman drwxr-xr-x 5 root wheel 62 Mar 12 22:15 lib drwxr-xr-x 3 root wheel 5 Nov 8 14:59 libexec drwxr-xr-x 2 root wheel 2 Dec 6 2018 media drwxr-xr-x 2 root wheel 2 Feb 2 2019 mnt drwxr-xr-x 2 root wheel 2 Dec 6 2018 net dr-xr-xr-x 2 root wheel 2 Dec 6 2018 proc drwxr-xr-x 2 root wheel 150 Mar 12 22:15 rescue drwxr-xr-x 5 root wheel 16 Apr 20 22:51 root drwxr-xr-x 2 root wheel 139 Apr 7 00:03 sbin
Thanks,
