As part of another, unrelated issue (https://www.truenas.com/community/t...that-have-different-numbers-of-drives.114316/) I've created a temporary second TrueNAS scale server for the point of creating a full filesystem replication that I can restore later. However, the full replication task fails consistently after about 8-10 hours. It produces an absolutely massive error that's too large to practically stick in a single forum comment or screenshot. However, the error is broken down into three message types, each repeated dozens of times for different snapshots or filesystems:
The first two ("skipping snapshot...") and ("full send size is...") seem somewhat informational, while the last one seems like an actual error. Can't seem to find a solution online, so I've either hit something very weird or I've done something super dumb.
Source TrueNAS server:
OS Version:TrueNAS-SCALE-22.12.3.3
Product:Super Server
Model:AMD EPYC 7302 16-Core Processor
Memory:63 GiB
Destination TrueNAS server:
Product:PowerEdge R720
Model:Intel(R) Xeon(R) CPU E5-2630 0 @ 2.30GHz
Memory:59 GiB
The replication task:
The source dataset:
skipping snapshot plex@auto-2023-11-24_00-00 because it was created after the destination snapshot (auto-2023-11-23_00-00) skipping snapshot plex@auto-2023-11-25_00-00 because it was created after the destination snapshot (auto-2023-11-23_00-00) skipping snapshot plex@auto-2023-11-26_00-00 because it was created after the destination snapshot (auto-2023-11-23_00-00) skipping snapshot plex@auto-2023-11-27_00-00 because it was created after the destination snapshot (auto-2023-11-23_00-00)
send from @auto-2023-11-22_10-58 to plex@auto-2023-11-23_00-00 estimated size is 624B full send of plex/plex-config@auto-2023-11-23_00-00 estimated size is 1.99G full send of plex/plex-media@auto-2023-11-23_00-00 estimated size is 4.55T full send of plex/.system@auto-2023-11-23_00-00 estimated size is 1.35G
cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/rrd-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/samba4': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/rrd-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/samba4': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/syslog-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/rrd-f1f5036a6e4448d09a9ddb3c45165866': pool or dataset is busy cannot unmount '/var/db/system/samba4': pool or dataset is busy Broken pipe.
Memory:63 GiB
Memory:59 GiB
The source dataset:
