lopr
- Mar 19, 2015
I have some problem to configure a pull replication task from my production machine to my backup device (both truenas)
this is the replication task on the destination machine:
these are the snapshots on the source machine:
but when try to run the task:
I have no idea what's the problem.. any idea?
source is 13.0-U1
destination is 13.0-U2
[2022/09/15 18:04:11] INFO [Thread-44] [zettarepl.paramiko.replication_task__task_3] Connected (version 2.0, client OpenSSH_8.8-hpn14v15)
[2022/09/15 18:04:11] INFO [Thread-44] [zettarepl.paramiko.replication_task__task_3] Authentication (publickey) successful!
[2022/09/15 18:04:11] ERROR [replication_task__task_3] [zettarepl.replication.run] For task 'task_3' unhandled replication error ValueError('not enough values to unpack (expected 4, got 1)')
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 181, in run_replication_tasks
retry_stuck_replication(
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/stuck.py", line 18, in retry_stuck_replication
return func()
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 182, in
lambda: run_replication_task_part(replication_task, source_dataset, src_context, dst_context,
... 1 more lines ...
check_target_type(replication_task, source_dataset, src_context, dst_context)
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 288, in check_target_type
source_dataset_type = get_property(src_context.shell, source_dataset, "type")
File "/usr/local/lib/python3.9/site-packages/zettarepl/transport/zfscli/__init__.py", line 108, in get_property
return get_properties(shell, dataset, {property: type}, include_source)[property]
File "/usr/local/lib/python3.9/site-packages/zettarepl/transport/zfscli/__init__.py", line 104, in get_properties
return get_properties_recursive(shell, [dataset], properties, include_source)[dataset]
File "/usr/local/lib/python3.9/site-packages/zettarepl/transport/zfscli/__init__.py", line 94, in get_properties_recursive
name, property, value, source = line.split("\t", 3)
ValueError: not enough values to unpack (expected 4, got 1)
source is 13.0-U1
