I've setup replication to a remote freenas box and since then, i find the following line in the auth.log of the remote freenas :
Jan 5 05:07:03 BoxNas sshd[3855]: Accepted publickey for root from 92.169.x.x port 12869 ssh2: RSA a7:55:f9:12:18:0f:d7:a6:40:e$
Jan 5 05:07:03 BoxNas sshd[3855]: Received disconnect from 92.169.x.x: 11: disconnected by user
Jan 5 05:08:03 BoxNas sshd[3905]: Accepted publickey for root from 92.169.x.x port 36712 ssh2: RSA a7:55:f9:12:18:0f:d7:a6:40:e$
Jan 5 05:08:03 BoxNas sshd[3905]: Received disconnect from 92.169.x.x: 11: disconnected by user
i have one login every minute during all the timeframe where the replication task is planned. The ip is the one of the other freenas box.
Replication tasks concern datasets that are snapshoted once per day before replication timeframe begin. The datasets are not modified during the frame the replication take place.
So, is this behavior normal, i mean having a login every minute ?
Feel free to ask if you need any other information, i do not know what can be useful regarding this case.
Best Regards,
Best Regards,
