Replication failed: I/O error
curtishall
I have 14TB of data I'm trying to replicate between two servers. I keep having problems where everything seems to be going well then suddenly it errors out:
New alerts:
* Replication "replication-11-27-2020" failed: I/O error
Command failed with code 1..
failed: I/O error
I've deleted all replication tasks and recreated them, which seemed to work but then it eventually failed out also. I then deleted the entire dataset on the second server and started over. After transferring 5TBish of data the replication errors out again with an I/O error.
Both servers are on the same network (currently), connected via 1000mbit.
Attached is the log.
  • 30877.txt
