SOLVED Replication Failed After IP Change
storage-junkie
I had seeded my secondary server locally, and then moved it to an offsite location that is connected with VPN. When I did this, the IP of the secondary server changed. I edited the Replication Task to reflect the new IP address, but there's something still wrong with the SSH key. This is the error I am getting:
Replication tank/repl -> 192.168.1.101:tank failed: Failed: No ECDSA host key is known for 192.168.1.101 and you have requested strict checking. Host key verification failed.
What steps do I need to follow to fix this? I'm running 11.1 U2.
