adrianwi
- Oct 15, 2013
I applied the latest update to my backup FreeNAS box over the weekend and have now noticed the following in the console:
The periodic snapshot is created at 02:00 on my main FreeNAS box, so assuming this is related to that. I didn't update the main box as everything was working OK but thought I'd test on the backup. Do they need to be running the same version?
And just tried to connect to the AFP share on backup and have lots of these appearing in the console:
Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error committing transaction: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing database name.db: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing database didname.db: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing database devino.db: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing database cnid2.db: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing DB environment: Bad file descriptor Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error closing DB logfile: Input/output error Mar 2 02:01:56 freenas2 cnid_dbd[3988]: error opening cwd: Input/output error Mar 2 02:18:23 freenas2 alert.py: [freenasOS.Update:801] Cached sequence, FreeNAS-9.3-STABLE-201502210408, does not match system sequence, FreeNAS-9.3-STABLE-201502271818 Mar 2 02:18:23 freenas2 alert.py: [freenasOS.Update:591] Cached sequence does not match system sequence
Mar 2 17:29:36 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:36 freenas2 afpd[3987]: transmit: Request to dbd daemon (volume APE_pool2) timed out. Mar 2 17:29:36 freenas2 afpd[3987]: enumerate(vid:1, did:2, name:'.'): error adding dir: 'TM_imac' Mar 2 17:29:36 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:36 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:37 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:38 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:39 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:40 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:41 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:42 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe Mar 2 17:29:43 freenas2 cnid_metad[2494]: error in sendmsg: Broken pipe .......
