kaz.williams
- Apr 15, 2020
Hello there :)
First off specs, let me know what other info would be useful and I'll include it!
Build: FreeNAS-9.2.1.9-RELEASE-x64
Platform: AMD Sempron(tm) 145 Processor
RAM: 20 GB
4x 4TB drives in a ZFS pool, I think it is a Z1, but I'm not sure how to confirm this, is there a command line way to tell?
One of the drives has apparently gone bad. First I tested the SATA connections and those appear to be fine, as when I swap cables between the bad drive and one of the good drives, the good drive still shows up correctly and the bad drive does not.
Here is the zpool status output:
And when I attempt to zpool import:
So after looking at the user manual and searching these forums, it looks like I need to use the GUI and replace the drive. However in my case, since the drive went bad, it appears that I can't even view the disks at all right now. My volume is still listed in the UI, but when I navigate to "View Disks" nothing shows up:
Is there a command line way to replace a failed drive instead? Or, do I have to do something first to get the pool back "online" for the disks to show back up in the UI so that I can select the bad one and replace it?
Thanks in advance!
RAM: 20 GB
[root@freenas ~]# zpool status -v no pools available
[root@freenas ~]# zpool import
pool: NIKUVOLZFS1
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see: http://illumos.org/msg/ZFS-8000-6X
NIKUVOLZFS1 UNAVAIL missing device
gptid/e5d8a4d0-0269-11e5-a419-bc5ff4ea1a9e ONLINE
gptid/e6749646-0269-11e5-a419-bc5ff4ea1a9e ONLINE
gptid/e70f2752-0269-11e5-a419-bc5ff4ea1a9e ONLINE
Additional devices are known to be part of this pool, though their
exact configuration cannot be determined. So after looking at the user manual and searching these forums, it looks like I need to use the GUI and replace the drive. However in my case, since the drive went bad, it appears that I can't even view the disks at all right now. My volume is still listed in the UI, but when I navigate to "View Disks" nothing shows up:
Thanks in advance!
