"Replacing" Disks in Pool
asw2012
I am replacing 2x disks with the "replace" feature. I see as the picture attached... But where is the progress of both drives so I know when to disconnect the old ones I am replacing?
Samuel Tai
Just watch the Events under Task Manager.
Or you can get some kind of progress from zpool status -v storagepool
asw2012
Thanks all, I've found the most useful is the command line, it shows which drives are still resilvering.
