replaced and onlined disk shows unformatted or unknow
Seans
I recently replaced a hard drive with the command : zpool replace VolMgmt ada4
The zpool status command shows my ada4 is already online, but when I go to disks-management, I saw the file system is Unknown or unformatted. Any idea?
Thank you!
sremick
You follow the documented drive replacement procedure as outlined in the user guide for your version of FreeNAS.
Seans
Hi Sremick, I read the document and did not find how to add zfs drive. Any idea?
There is no method, GUI or CLI, to add a ZFS drive. There is a documented method to replace a drive in section 8.1.10 of the manual (doc.freenas.org).
